manual boost controller, need help
Mrnazmi
510
29
3,028
Drag City
Yes ^pomen_GTR^, both way can be adjust, the main function of fish bone is to have some leaking so that we can increase the boost pressure..:driver:
More boost, more fast!
Over boost, keter terbabas! Hehehehe...:burnout:
haha...ok..noted that....
speed2horizon
2,798
334
1,683
Works Manual Boost Controller ok ka if to play higher boost (up to 1.5 bar)?
Currently using fish bone (tulang ikan), not really accurate, still searching for another manual boost controller that cheaper...:driver:
p/s: If got budget wanna buy Greddy Profec-B II, huhu. But for now manual boost controller is the best option. (no money no higher boosting..:bawling:)
Sure... Provided u are using wastegate. Instead of installing the boost controller at the bottom port, U can T it from the boost source(IC Piping) to BOTH top and bottom port of the wastegate.
Have the boost controller to installed on the top port instead. by doing this, instead of bleeding the compressed air out to cheat the wastegate, u are acting it the totally opposite way. U will allow the spring assisted with compressed air to push the wastegate down to achieve more boost to counter the spring rate + altered compressed air. By doing this, u can achieve more stable boost.
BUT BARE IN MIND!!! BY DOING THIS, THE BOOST CONTROL ALSO WORKS OPPOSITE WAY. OPEN ALL THE VALVES FULLY IS REDUCE BOOST. CLOSING ALL THE VALVE IS MAXIMUM BOOST.... PLS BE CAREFUL ON THIS!!!
there is a hose from the exhaust manifold connected to the actuator, T-bridge it, using the 3 valve tulang ikan, keep the valve open by 1.5, and the 3rd one closed. this will give about 0.8 bar boost to ur stock turbo
This is not entirely true... Even if u are buying Turbosmart boost controller, the same ammount of turns will react differently on different engine/turbo.
Lebih lebih lagi, Tulang IKAN...
BTW, where is the hose from exhaust maifold comes from..? It's the hose from the IC piping or compressor outlet that connects to the actuator.
errr...2different answer....
i guess both way boost still can be adjusted rite???
From wastegate / actuator got one hole there, put the vacuum hose there and join the tulang ikan in the middle of the vacuum hose, and continue the hose to the intercooler piping (make one hole there near to t.body, after the B.O.V. holes)
Please top up some more if my explanation is not clear..hehe.:driver:
Where got different answer... =.=
SAME MA.... Sandwich the BC within the IC piping and turbo.
Newbienissan
Banned
Jul 19, 2010
279
17
518
earth
wait ar, i think i go take photo of my trusty L2 engine bay first....hehe
---------- Post added at 11:10 AM ---------- 6 hour anti-bump limit - Previous post was at 10:37 AM ----------
wasteg4te
154
9
jb
regarding the work boost controller...
how much ar?
and
what the posible (Common) problem will facing when used manual bost controller?
Hi! guys!!! :biggrin:
just want to ask bout' what is a difference between LSD Gearbox & Full Lock Gearbox coz' I'm lookin' an Evo3 g/b, I goes to some chop shop n ask for g/b, I said I want a it wit LSD but the guys said it is a non LSD g/b but it can be Lock to 2 wheel, I'm quite confused here :hmmmm: , is it mean that from 4wd lock to 2wd or from non LSD to LSD, some of the thread in the internet (not only ZTH) also wrote the same "Evo3 g/b for sale, non LSD but can Lock to 2wd" I know...
