looping wiring in an amplifier
takumi_86
i am using a cap ayam amplifier 500watts,2 channel and a pair of jbl mid speakers,each is 120 watts,i would like to add a pair of oxygen componets speakers. The question is , can a 2 channel 500wats amplifier being loop(wiring) into the jbl mid speakers and the oxygen components speakers?. tq and need and advise . :)
that depends if ur cap ayam can really play 500 watts?i think u can add,but the sound wont be so powerful dude. i suggest u buy another amp even if its ayam to power ur comp.
can either connect it in series or parallel... series will get 8ohm, less power out put & ... parallel will get 2ohm, double up the power out... hope you amp is stable at 2ohm..
most amps should be stable to 2ohm in stereo mode...
