knuckle's question
jlck
Hi all. for sure everyone here know tat the EK9/DC2 knuckles are different from other ( EK4,EK3,EJ6 and else), 5 bolts and 4 bolts. I just wanna ask here isit the the bolt on the knuckle for brake calipers are different as well? i mean the bolt's size.
becuz im plannig to change my brake calipers without changing the rotors (EJ6) isit possible to fit in whatever brake caliper for EK9/DC2 ?
Thanks. Appreciate for the reply.
Hi JINEL2EN, tats mean i can fit the spoon caliper (for EK9) in my EJ6 rite, as long as the rims can clear it?
But you have to drill new holes for your four lug setup anyway, so does the bolt size/pattern matter?
I seem to understand that you want to fit a 5 lug disc into a 4 lug knuckle.. sorry if that's not what you're attempting to do.
Not same, bro. Ej6 rotor is 260, ek9/dc2 5lug is 280. Spoon caliper direct bolt on for ek9 with 280, need to cut n modify ej6 knuckle for 260 rotor to fit longer spoon caliper leg.
haha...i mean the knuckle is same, but not other things....u can't direct fit the spoon to ur EJ6, atleast u must change to EK4 knuckle. if not.
