Ding Dong, Pagging for Mr Ram, my friend is scrapping his EK in spore. All price qouted in Sing Dollar
B16A2 Cylinder Head (Fully ported)
500 -
Hasport EK1 steel mounts
350 -
Front and rear spherical camber kit
250 -
ASR subframe brace reinforcement
250 -
EK9 22mm rear anti-roll bar w/links
150 -
UR Front Fender brace
50 -
Custom intake manifold
300 -
DC2 Header + Heatshield
250 -
HKS Hipermax II
650 -
PLX M300 calibrated wideband + Bosch O2
200 -
S4C EK4 Transmission
300 -
Spoon calipers
950 -
Custom billet aluminum brake MC brace/stopper
50 -
JG Engine dynamics cam gears (2pc set)
120 -
GSR crossgear set with 0.787 5th
400 -
Modified EK9 shifter linkage + Blox shifter + Skunk2 shift knob
200 -
Rare ARC/Koyo 54mm aluminum radiator
350 -
Samco hoses (1-set) with HKS water temp sensor sleeve
100 -
Neptune RTP ECU with harness
800 -
Custom PreFL EK4 Rear fibre decklid + FL EK tailights
400 -
EK9 Cams + Valvesprings + Ti Retainers
500
EK9 Undercarriage with new Hardrace spherical bushings, bearings and ARP extended wheel studs
1200
http://www.hardrace.com
Custom Billet fuel rail and fittings + H22 Injectors
250
Fuel Rail + full Earl's braided hose set
200
Unorthodox Racing power steering pulley
100
S2000 steering wheel (fits DC5, EK, ES, BB6,
does NOT fit EG)
400
S2000 cluster
650
comes with speed sensor converter, temp sensor converter and fuel gauge adaper, can fit ANY car, but this is a DIY-mod and i doubt any workshop can help you out and i have no time, if you're brave and familiar with electrics and don't mind re-wiring your dash and VSS, then you'll have a very special cluster.. if not i suggest you don't consider this.. minimum offer i got is 490USD so i might just pass this on to my US friends on my next trip
Tuner Harness OBD2A -> OBD1 (for Hondata/Neptune on EK)
150
Goodridge steel braided brake hose set x4
150
B20 forged 85mm lower block
2500
Forged CP Pistons 85mm, custom 5.531" Eagle rods, rod/stroke ratio better than B18C5
Block guard, custom crank, block girdle
AEBS 68mm Throttle body
200
MSD Cap + MSD 54KV E-coil + NGK wires
200
