- Joined
- Aug 18, 2006
- Messages
- 316
- Points
- 1,518
Use solvent can remove it,damn simple only....
Hmm might be out of the subject but I think some of us might want to know including me. For the road tax disc that have been removed there are some adhesive residue stuck to the windscreen. It might not be a problem to use petrol of thinner to remove it but since I have a layer of tint on the windscreen, will it damage the tint? What is the best solution without purchasing those adhesive remover which I only use once in a blue moon? Sorry TS hijack your thread a bit.
But where to get mineral spirits? I use WD40 because it is widely available at almost any store. I then clean up the oily residue with all purpose cleaners after that. Not really much trouble and fast because car decals are on a small spot only.
Plus, not all mineral spirits are safe. I've tried a few before including acetone and ethyl acetate (nail polish remover). I found out that some of these actually dissolve your paint. Luckily I tried it on my own car. The reason I use WD40 is because it clearly says paint-safe.
If need to use APC after using WD40, why not just use the APC itself to try remove the stickers
There are generally 2 types of solvents. The organic (non-polar) and non-organic (polar).
Can use APC or OPC straight. But like I said, not all is easy to remove with those. Because gums are mostly organic and needs a non-polar solvent. I'm sure OPC and APC can also, but takes longer time and effort.
