How much boost?
Cow
Guys,
anyone know how much boost the stock evo5 gasket can handle?
i think 1.3 is max ! if air fuel cannot target can burn the engine !
Yeah .... better not boost until 1.6 man .... bakar your head gasket ... then teruk ....
Last time i kena .... cepat2 go change Metal head gasket .... :bawling:
Use for few years until recently middle of this year the gasket also bocor ... so i hantar go workshop change metal head gasket lor ... :proud:
This topic already discussed a few times already. Do a search ..
***Pls. see my signature***
ok thanks guys :)
can ignore this topic already:burnout:
sorry cow... just 'tumpang' the thread...anyone here can share some info...about metal gasket...0.7mm, 1.2mm and 1.6mm ...each of them for what purpose??? why there's different thickness.?:hmmmm:
To adjust your compression ratio bro ....
Yup , i know that... but mayb some of us can share more info...something like..(this figure IS NOT true one)...i guess only :hmmmm:
a) 0.7mm (compression 8.5:1) safe to boost max 1.5bar
b) 1.2mm (compression 8.0:1) " boost max 1.8
c) 1.6mm (compression 7.5:1) " boost max 2.2
who can share or advise on this...tq:biggrin:
a) 0.7mm (compression 85.5:1) safe to boost max 1.5bar
b) 1.2mm (compression 85.0:1) " boost max 1.8
c) 1.6mm (compression 84.5:1) " boost max 2.2
Bozz, it doesn't work that way .....
read this ....
http://www.everything2.com/index.pl?node_id=766464
**Quote**
Examples:
basic
Stroke 100mm
Bore 87mm
gasket thickness ... i dint know but worked around
comp ratio = (cylinder volume + combustion chamber volume)/ combiustion chamber volume = 9.5
combustion chamber volume = some complicated stuff + head gasket volume
- head gasket volume = (.5bore ^2) * pi * height(thickness) = 69937.3965 (using algebra and solving for this in above formula w/ the 2 knowns)
cylinder volume = (.5bore ^2) * pi * stroke = 594467.87
to achieve about ~ 8.9:1
assuming
X = desired compression ratio
TCV = CCV + G = total combustion chamber volume
CCV = combustion chamber
G = gasket volume = (.5bore ^2) * pi * height(thickness)
using some algebra that would be tedious to type we get:
Cylinder volume = (X - 1) TCV .. some more algebra etc
To find a thickness to get u around 8.9:1
594467.87 = 7.9 * (69937.3965 + G) more algebra solve for g or shouldve done it earlier..
G = 5311.70095 (volume of addditional gasket) now solve for thickness
assuming the new gasket has the same bore as the cylinder (87mm)
additional gasket thickness would be ~.89 mm or ~.035 inches to achieve static 8.9:1 compression
an additional .025 inches or .635 mm should bring down the compression ration to about 9.0647:1
assuming the same bore as the cylinder.
Now u just need to know your original head gasket thickness.
Source from the above link & some other websites (rpw & EM). Figures purely theoretical.
Bear in mind that the piston tops are not flat landings ...
**UNQUOTE***
Thanks paul, this is what i need...really useful info...:biggrin:
U ONLY option (c) lah .... :thefinger::rofl:
***Pls. see m signature***
Sigh!!! I think i hv boost leak pro le... My setting now - low 1.3 n high 1.5, mainly using low boost for street... But from my peak record, de cibai boost meter shown close to 2.0 la~ What's de pro?! Time to change to wastegate or at least get a brand new after market actuator? Pretty worrying, takut boom my 2nd turbo again!!! LoLzzzzzzzzzzzzzz... :biggrin:
aiya towkay...just install after market turbo kit la...and FCON V...your problem solved..:listen:
SV9, Cheaper option (if u can find some1 to lend u their actuator for checking purposes) ... If after testing confirmed actuator kong, then can get an aftermarket lor ... or ori ...
My 2 cents worth of thoughts!
Hope u get to the root of your problem soon.
Write your reply...
