Hi Cams Specifications
jinkl
here are some info for u guys
Factory EVO
Advertised Duration - 260 deg Int / 256 deg Exh
Effective Duration - ___ deg @ 1mm Int / ___ deg @1mm Exh
Lift - 10.0mm Int / 9.5mm Exh
Lobe Centerlines - 109 deg Int /111 deg Exh
LSA - 110 deg
Stock valve springs OK
JDM EVO MR
Lobe Centerlines - 113 deg Int /112 deg Exh
LSA - 112.5 deg
Comp Cams 264+
Advertised Duration - 248 deg Int / 248 deg Exh
Lift - 10.8mm Int / 10.2mm Exh
Lobe Centerlines - 104 deg Int / 112 deg Exh
LSA - 108 deg
Upgraded valve springs recommended
Comp Cams 272+
Advertised Duration - 256 deg Int / 257 deg Exh
LSA - 108 deg
Comp Cams 280+
Advertised Duration - 264 deg Int / 265 deg Exh
Lift - 11.0mm Int / 10.4mm Exh
LSA - 108 deg
GSC 264
Advertised Duration - 268 deg
Effective Duration - 194 deg @ 1mm
Lift - 10.6mm Int / 10.0mm Exh
Lobe Centerlines - ___ deg Int / ___ deg Exh
LSA - ___ deg
GSC 272
Advertised Duration - 281 deg
Effective Duration - 203 deg @ 1mm
LSA - ___ deg
HKS 264
Effective Duration - 206 deg @ 1mm
Lobe Centerlines - 110 deg Int / 110 deg Exh
LSA - 110 deg
HKS 272
Advertised Duration - 272 deg
Effective Duration - 214 deg @ 1mm
LSA - 110 deg
HKS 280
Advertised Duration - 280 deg
Effective Duration - 222 deg @ 1mm
LSA - 110 deg
JUN 264
Lift - 10.5mm
LSA - ___ deg
Upgraded valve springs required
JUN 272
Effective Duration - 235 deg @ 1mm
Lift - 10.8mm
Lobe Centerlines - 110 deg Int / 115 deg Exh
LSA - 112.5 deg
Piper Ultimate Road
Advertised Duration - 265 deg
Effective Duration - 217 deg @1mm Int / 211 deg @1mm Exh
Lift - 11.5mm Int / 10.8mm Exh
Lobe Centerlines - 108 deg Int / 107 deg Exh
LSA - 107.5
Piper Rally
Effective Duration - 217 deg @ 1mm
Lift - 11.5mm
LSA - 107.5
Piper Race
Effective Duration - 224 deg @ 1mm
Lift - 12.0mm
Lobe Centerlines - 106 deg
LSA - 106 deg
Revolver 262/264
Advertised Duration - 262 deg Int / 264 deg Exh
Effective Duration - 222 deg @ 1mm Int / 223 deg @ 1mm Exh
Lift - 11.4mm Int / 11.5mm Exh
Lobe Centerlines - 109 deg Int / 111 deg Exh
LSA - 110 deg
Tomei Poncam
Lift - 10.7mm Int / 10.2mm Int
LSA - 112.5 deg
Tomei Procam
Lift - 11.5mm Int / 11.5mm Exh
LSA - 112.5 deg
those procams not street driveable...even 272 also felt damn sluggish off boost..SiGh...
