I want to replace the C52 that i have with a C56 LSD and I need help with the following questions:
1- how can i tell if the C56 have LSD or not? i tried placing the two axels and move one while holding the other and both of them moved in the same direction, does that mean that it's LSD?
2- which oil should i use for the C56 LSD and how much oil do i need to fill it?
3- the C52 gear ration is very long, 1st 80KPH, 2nd 120KPH, 3rd 180KPH (4th and 5th I don't know since my car max speed is only 180KPH) , what's the speeds for the C56 LSD 1st, 2nd, 3rd, 4th and 5th gear?
4- do i need to replace any other parts (axels, clutch .. etc) for the C56 LSD?
5- There's a flywheel with the C56 LSD that might be lighter than the OEM BT flywheel, is it better to have a lighter flywheel? the OEM BT flywheel is around 6KG if this one is 5GK or less, should I use it or keep the OEM one?
6- Is there a noise for the C56 LSD even if i use the proper LSD oil? is it a loud noise? is there any video that shows what's the normal C56 LSD noise?
thanks for your help,
