Help! unbalance sound
wsonny
Ampang
Need help,
i know sure wat happen to my sound system which the sound come out unbalance, right speaker louder then left speaker. Btw i'm using 6" component speaker wit 4 channel amp and a subwoofer. Someone told me tat it might cause from the RCA cable need to change. can anyone help or any recommendation for audio workshop near cheras or ampang area.
Thank you
have to trouble shoot which item is the problem, could be the speaker, or the passives, or the speaker wire, or the amp, or the rca or the rca output...
Sometimes it back to normal then sometime it unbalance....
stan, if you can switch the cables easily then try that.. that way if this thing still happens and the right side is the louder one then you have confirmed that it is _not_ the rca cable..
instead, if the left side gets loud then you confirmed that your rca cable is the problem, and this should be a simple fix... :proud:
