Help on underglow
sooyeshun
Actually i dun go shopping for car parts...
recently i see a fren's (not close) car...underglow is quite nice...
not like ah beng type wan...
looks exactly like 2 fst 2 furious wan...
normally when you put underglow your car , it cant really glow everypart beneath your car ...but his one can...
ok, actually i need you guys help me ....where can i get the besy underglow and roughly how much issit..
i think i'll DIY myself ...roughly tell me how much it needs ...erm...how to DIY ...i duno lehh...
Glowing everywhere under the car is what in ur perspective of being not ah beng? then i would suggest u mount the light at place where not obstructive object around the lights.
Neon light is not cheap. If u want it flow at everywhere, might need RM300 for the light, totally 4 long tubes i think. I saw the neon light in brothers but not sure of the color. Most possibly blue color only.
DIY, what u need to do is tap electric source to light, wiring, mounting, on/off switch, fuis. The process is subjective, depend on how u want to do it.
4 tubes???
dun need gua..
his car...i squad down and see only 2 tubes lehhh....seeing from far or near also cant see the tubes..unless you squad...
but underneath the car total bright lor
Then you might not have seen the light from behind lo...only beside
ok ....
can quote how much ar???
erm...from brothers???
enous got or not..
where else can i get ar??
how much installation???can quote..
thanks jaywat
I never went to eunos before...brothers sell for 70-80 like that, if not mistaken...the tube is damn long..around 4 feets.. which i think quite reasonable.
i myself use fluorescent tube, damn a lot cheaper :D
use flourescent tubes lar.... just mount them properly.. then ok.. make sure u have some big skirtings to hide them....
check this out.. my car... but not big big skirtings lar... :D
http://khguan.fotopic.net/c437171.html
not neon tube?? i'm not sure also, i judge it from the diameter of the tube only...r u seeing at the same tube i saw?
wats the difference between florencene and neon wan...
i want cheap wan only,,ahaha
mana cari?
I tot you want the best one?? neon light is like those u saw on advertising board...fluorescent is the one on ur ceiling..for cheap one, go for fluorescent tube instead,...one 2 feets tube only RM7
now they have this thin flourescent tubes for display cabinets.. price also similar.. but thinner lar... u can use this if u really wanto hide de tubes...
i already planning to install one into my bumper...
wow....a nice samaritan...u wann haelp the bugs and cockroaches cross the road?
CCFL... ? Mostly used for computers... They are not very bright though... And certainly not water proof..
You need to build some kind of protection container for them... Or you certainly don't want 500Volts of AC electricity to short your car... :D
nop... not CCFL... its flourescent... but very thin wan.... diameter its around 12 mm... i tested.. quite bright... de length is 19" (16W)
so no need to worry for water... i just need to get a clear water hose to protect it from break during installation...
got one tube that khguan mentioned... later on i post the picture...
here is the tube
here is the tube
yah.. this is de tube i meant.... but this is with de holder.. which connects to a 240V AC input...
my coming DIY project will onli use de tube... conected to the room lamp circuit...
Write your reply...
