saiyuke,
What you can do is put your car into 4th/5th gear, drive it up to around 4500-5500 rpm and then try to modulate your throttle by gently lifting and reapplying pressure on the accelerator.
If you are having issues with the SSQV, your throttle inputs will be juddery rather than smooth. There really is nothing you can do if this is the case, it's just that the EVO doesn't like atmospheric valves. Don't go and adjust the SSQV (if yours comes with the adjustment screw) as this will only increase compressor surge, not a good thing with the IX's turbo. If it's smooth, then you're probably fine.
Did your car come with the SSQV or did you swap out the stock valve?
