GearBox Replacement
viostar
Dear all,
I having problem with the GearBox (Wira 1300cc), need advise change Recond or 2nd GearBox?
Cost only different RM 100 for 2nd & Recond. 2nd cheaper RM100. So which to take ?
Current GearBox bearing spoiled, Gear oil keep coming out after replace the new driveshaft oilseal..... but funny thing is the GearBox housing no crack.
Hight percentage is the bearing inside of the GearBox causing the Gear oil keep coming out after new Gear oilseal changed.
Thx.....
If u really want to change better change chop shop one..
Recond hard to believe.. anyway.. its still ur choice..
Buying things actually is depends of luck.. no matter new or 2nd or recond.. no luck, will spoil also...
GB Kong? can consider to change engine liao lol..4G15...better FC, power and more...
Good Luck
Hi,mag9556....
Yup, the machanic told me to take 2nd hand instead of recond, because 2nd more reliable.
Today fixed liao loi....... changed GearBox, Clutch Set & Master Brake Pump.
Result first impression quite good, car drove from workshop back home was OK. But never know must try for few day than see how loi......
Why said 2nd better than recond??? hard to understand!!!! can tell me ka?
Thx....
Hi,mag9556....
Thx....
Actually Chop Shop better coz of it is still virgin...
Those recond wise.. open before and dun knoe what they have done inside it thus change those chap ayam part inside to cut cost...
Hi mag9556,
Thanks for the advise.
Now driving quite smooth compared to previous. Gear in or out smooth as well. clutch press also lighter than before.
But is there anything else to check it out.
Thanks.....
