gearbox change.
Ashyie_Ferio
currently using auto gearbox.
going faulty.
fried clutch plate or sumthing.
thinking of changing to manual.
any problems or advice regarding gearbox change?
of course the benefits to change to manual
pros
- better FC
- better performance
- much more lasting
- easier to service.
cons
- cramp during jam if using 4 or 6puck clutch plate haha...
- wife or gf complaint.
anyways, must as well save up abit & get b16a manual halfcut.
http://www.mudah.my/Honda+EG9+B16A+Engine+Manual+Transmission+LSD-8331304.htm
or maybe get a recond autobox.
http://www.mudah.my/Gearbox+honda+B16A+auto-8373511.htm
im really interested in manual. however, got no money to change the engine..
so, prolly gona use my existing engine, change to manual.
so no problems if change rite? i mean problems with engine or stuff.
pros
- better FC
- much more lasting
cons
That is so true. Especially our last point LOL!
---------- Post added at 12:40 PM ---------- 6 hour anti-bump limit - Previous post was at 12:38 PM ----------
Bro I started a thread on this.... Im also trying to swap manual into my auto. Maybe you can refer to some opinions here... hope to get this project done after cny as workshop is closed now...
Will advise you on my project if jadi..
Btw, the thread : /www.zerotohundred.com/newforums/car-modification/365162-auto-gearbox-convert-manual.html>
i heard from a friend if want to change to manual,
need also change the engine?
is this right or wrong?
i think only gearbox need to change right?
a gearbox compatible with the engine,
then clutch pump, and pedals.
that is all right?:driver:
no need 2 change d engine, just change the gearbox, clutch plate etc.
add one more pedal need to drill one more lubang beside brake pedal
can keep same ecu, but better change to manual one, or not get e-manage i think
thnx bro.
the cost, just a lil bit extra than change auto gearbox right?
auto to manual conversion needs to change gearbox only(try to find complete set incl. pedal,flywheel,gear console+lever/shifter,if using cable also clutch cable,replace new clutch lining+cover,gear oil.....if got extra rechip ecu,change meter:burnout:
done for my bro's eg8 cost around rm2k++ :biggrin: pricing for kch area:driver:
thnx for the info bro.
but im gonna stick with auto since my dad hasnt given me the green light to change to manual.:bawling:
hehehe.
1.2 k.
not bad i think.
hehehe.
1.2 k.
not bad i think.
aiya, sometimes u break d rules, skipped the red light, rite? a bit risky but exciting . . . :evil:
he heee
