Gearbox and suspension top mount
jebWKM
70
Hey guys,
Do any of you know what manual gearbox can fit waja engine 4g18p beside waja gearbox of coz... if a turbo engine gearbox will be even better.
What upper pillow ball mounts can fit waja? running HWL currently.
Thanks guys in advance :_:
weikhee86
423
yo...better if u tukar one set at one go...engine + gearbox...much safer n won't cost u problem in the later days...both are like husband and wife...inseparable...if u wanna tukar gearbox might as well tukar engine cos more ngam...but waja FF ler.. if not FF can pakai evo one..a bit hard..
jebWKM
70
thanks for your advice... but i am having abit of problem with my gearbox... sympthoms coming out... driving fast not so obvious but during jam... cruising about 40 or lower... from second gear to 3rd, it goes to free gear for about 1 second then only engage... like currently on second.... going to change to 3 gear... vroommm... free gear... then toomb... 3 gear....
so thought of changing manual and if turbo gear box better incase wanna bolt on or something...
The Marketplace Top Posts
1. I want more power and the engine is detonating! Do I need to run richer to eliminate the knock?
What is the optimum air-fuel ratio to run for best power?
I've heard racers say that we need to run a bit lean for best power - is this true?
Maybe. It's somewhat true that running a tad bit richer will help quench detonation (knock), but only to a certain extent. The stochiometric AF ratio for gasoline...
