gear 5 always tendang2..help!!!!
blitz_811
waa..
can somebody suggest somewhere around melaka can fix my problem..
My satria 1.6 4g92 sohc got problem laa gearbox, gear 5 tendang laa..
also..
what is standard cost to fix this problem..xnk kene tioww lorrr..
:cry_smile: :cry_smile: :cry_smile:
Since still can use gearbox 4, then go back to your place and find your machenic to repair. 1.6 gearbox very expensive. If not mistaken, the price would be around 800.
pop out?means jump down..samela kot..any suggestion bro from mitsubishi part?
very expensive lor..800. is it mivec part can fit?cost?thanks..
5th gear syncromesh gone la friend.
either get replacement part or change whole gearbox...both also almost same price.
blitz,
Mivec part huh? One mivec gearbox now can sell for 1k+. What do you think? Somemore you uses mivec gearbox for such close ratio, FC will be high.
Get 1.8 gearbox. Worth it.
1.8 gearbox....mmm good idea,thanks bro..how about the cost aa?big problem..waa!!after hari raya I found my money loss big laa..too much rendang expenses laa..huhuhu
haha...
Mayb is around 1k. Less than should be. Last time I got one offer for GSR gearbox is around 950. 900 already can get. mmm... not really know about the cost. You may need to research from those chop shop.
at last i've found marvellouse mechanic at Bt. Berendam..cheapest n creapest also dabom!!hahaha..thanks to you guys!!
Write your reply...
