Fully utilise Haltech E6X
spuzzle
Kuantan / Perth
Hi all,
I heard of a fren who is using miss firing system on his haltech E6K. Anyone can elaborate on how to activate this system on E6X? Need any external support?
What other system that have on E6X I can use for my turbo engine? Currently only running boost solenoid. thanks in advance
u can ask n refer to a member named EG9 to solve ur problem bro...
he is a pro on ECU....
anybody have sofware e6k version 7.07.plz help me i really need this software :adore:..
To day im intresting with Haltech Pro sofware.that's why i like to touch the Pro ECU.Hope success like APC and Rob Barec using the Haltech.:biggrin::biggrin::biggrin:
there are 4 output for the E6X.. PWM#1 to PWM#4 ... the misfiring system you mentioned should be the Anti-Lag which you can choose under the PWM#1-#4 ... You still need to add a switch to activate the Anti-Lag which the switch you need to connect it to Aux-In wire...
if you good in wire and ecu tuning .... it should be no problem ...
if you are not ... it quite complicated....
you can refer to GT-Auto or
Under5ive garage also good in all range Haltech product...
