Front Speaker size 4 wira aeroback
jattaalaf
Hai... i'd planned to fix component set to my front door panel but i dont know what is the maximum size that i can use. Is it 6.5 inch is too large? So guys, please give ur opinion to me. Thanks....
p/s: car type : wira aeroback 1.5A
amboi bukan main lagi, paling high end plak dia rekomen, kurang asam.....dia mintak saiz je baru.......
for wira normal 6.5" no problem, just a little work...
Stock Wira Aeroback door speakers are 5.25", but no problems fitting in 6.5" with the use of a MDF baffle :regular_smile:
ok....but how to modify. Another thing is tak sangkut kat cermin ke magnet die tuh?
6.5 inches? Because a guy from car accessories said the maximum size is only 6.inches.
Tapi ingat mmg nak pakai 6.5?
Can u please explain to me about that? Thanks in advance.
mana ada speaker 6.1" haha...
either 5 1/4 or 6 1/2 je
semua bisa diatur la, installer punya keje dia tau la cemana nak kasi fit. usually tambah kayu so tingkap tak kacau...
Modify as in removing the stock crap plastic bracket, and making a new bracket from MDF(Medium Density Fibre) for it, usually 1/2" will do i reckon, most reputable ICE installers would be using the way describe, won't kacau with the power window, and there's rarely any 6" components, usually 5.25" or 6.5", unless you using DIY components then i know got 5.5" la... ;p
