stock turbo car's from factory , doesn't come with turbo timers , cause the turbo gets enough cooling already .
me too. i take out the water cooling for my turbine.Originally posted by MitonCT26@Mar 8 2005, 10:01
modified turbines if still using water cooling for their shafts should not have problems...
mine dun have so before i reach my destination i bawak slow slow...let the oil cool down first. :lol:
stock cars with stock turbos have no boost meter, no turbo timer, no loud exhaust and no blow off valve sound. :P
Cool bro!!!Bro u usin vr4 i/cooler or gsr i/cooler n usin ori radiator?? hehehe would like to know.... :D :DOriginally posted by Itab@Mar 8 2005, 21:54
BooN.....me using GSR turbo for more than a yr dee leh....nv once overheated,somemore i traveled on highway quite often,KL-MLK,MLK-JB,KL-JB....all no problems at all.....
IMO, better use the standard radiator that comes with your engine. should be okay. because engineers have already designed the best radiator for the engine's application.Originally posted by BooN@Mar 8 2005, 21:48
bout the radiator laa... is it bigger radiator will make the engine cool more than before? :blink: if i am not wrong our malaysia weather is too hot for turbo...... :(
hehehe std radiator should be okay, unless u are running big piston with thin water jackets. otherwise std cooling system should be okay. should monitor temperature. if it goes higher than normal, something wrong. better attend to the problem soon or else it will cause big headache not to mention burn a big hole in ur wallet...Originally posted by BooN@Mar 8 2005, 22:11
khoyos... as u know la the designer for turbo engine design for their country weather .Like japan quite cold at least more cold than malaysia. I jes tot to use a bigger radiator to keep the engine more cold. Do correct me if i am wrong.... :P soli to interupt.... ;) CheerSS...
U need a supercharger!!!Originally posted by razaksa@Mar 8 2005, 22:56
i wana improvemy low to mid end torque and hp from 1k-4krpm of my 1.6L M/T Gen2..what type pf turbo is recommended.. iwant quick spooling, zero turbo lag instant boost response from 1 k onwards...thanks pref boosting 0.5 bar to 0.7 bar without changes to engine internals...any suggestions?
U need a supercharger!!! [/b][/quote]Originally posted by AlucarD+Mar 8 2005, 23:10 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (AlucarD @ Mar 8 2005, 23:10 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-razaksa@Mar 8 2005, 22:56
hehehe std radiator should be okay, unless u are running big piston with thin water jackets. otherwise std cooling system should be okay. should monitor temperature. if it goes higher than normal, something wrong. better attend to the problem soon or else it will cause big headache not to mention burn a big hole in ur wallet...Originally posted by khoyos+Mar 8 2005, 22:16 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (khoyos @ Mar 8 2005, 22:16 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-BooN@Mar 8 2005, 22:11
hehehe thanks a lots for ur advise!!! reli reli appreciate.... but if i wan change bigger i/cooler will make turbo lag a bit rite?? any solution??? or use all standard the best??Originally posted by Itab@Mar 8 2005, 23:25
BooN,me using stock GSR intercooler,but i don think tht has much to do with the cooling of the engine,in general bigger i/c gives cooler air,thus more dense air with more oxygen molecules per volume,so gives u better power only,but too big an i/c also increases lag la,so depends on wat engine n the size of your turbo lo
me also using standard radiator...and as i said,darn bloody reliable...no joke,nv once overheated
but as turbo user i check on the engine oil level and reserve water tank level every now n then,much more often than usual la,since i always travel on highway
Similar threads | |
