bro..im using wira aeroback.SE 4g15stock..can the eg/ek radiator be fitted? do i need to change the radiator hose(if not same diameter)? is the inlet/outlet same as stock wira? do i need any modz? sorry if too many question..need to make sure before planning to buy ^^,
I'm just wondering if i put the hose from inside cabin directly to intake manifold. Or more on that, install it from Air-Cond hose directly to intake manifold(make one hole, and put an intake hose on...
Ok here is an idea. Electronic turbo...mild boost. Get a turbine and modify it to fit a 12v high speed brushless motor (seen some at 70000rpm at 50kW)....Drive the compressing blades into trottle body. Turn on only...
