Engine Oil
simplythebest
Selangor
Heard from a mechanic, after drain out all the oil, it should be around 2 litres. If less than that amount, something is wrong at somewhere. What is the problem?
engine start to eat oil / oil leaking.... sometime change the gasket can help .... try to ask the mechanic for more accurate info :)
Anyone here use Total Quartz7000SL 15W-50 Semi-Synth.? What's your comment to this compare to the more establish Mobil/Shell/Castrol/Caltex?
use Q8 if wan performance..............if wan normal use then dun need compare brands...all r same <_<
watever u use..the engine oil purpose is protect ur piston n cyclinder..just choose the velocity that suitable ur car n always change in right time..wat famous brand almost the same,if u always gone for hi-speed then u have to mention the flashpoint of the oil..normally good engine oil flash point till 220`c,just dont buy unknown brand only
Write your reply...
