conversion help!!
smallV
im using DA7 rite now wit b16a small vtec auto,
my project now wants to convert it to manual,
use ek9 LSD gearbox,flywheel,clutch etc,
so wut i must do 4 the conversion..
can i use auto ecu??
how bout the gearbox,can plug n play or need sum mod??
how bout clutch,cable or hydraulic??
i need y'll idea..
tq
small v,
its recomended to get a manual ecu n ther wud b a slight mounting modification for a DA7 body....all ek9 gearbox cum wit hydraulic clutch....gd luck bro...
there are just too many parts involved when it comes to gearbox conversion. especially auto to manual with a hydraulic system. too expensive also.
get a manual DA6 manual halfcut and take every manual component there is.
i need y'll idea..
tq
tq integram, but i need more information bout this,if sum1 ther already done this conversion can share it here..
tq j101
da6 use lsd o normal??
the prob is i need lsd :) ermm.. how bout da8 component??
small v,
da8 components cums wit cable clutch.....if u r lucky u mite get a da8 gearbox which is cable driven dat cud use EG or EK clutch which has a bigger sub unlike da EF9 gearbox....dat wud b muc more convinien n cost wud b cheaper den an EK9 gearbox........
i did convert my gearbox fm auto to manual bfor bro.....gud luck.....
common bro... need lsd ofcoz 4 sumthing :) y?? do u hv any opinion??share it here.. :) pro n con of lsd..
they are optional items from honda and the older generation uses clutch type lsd. do think abt wear and tear especially these old models.
there is nothing wrong if you get the da8 "big vtec" gearbox..the thing is..your engine, ecu, meter cluster are all auto..it takes too much money to convert all those. even if you convert the gearbox, the engine is still auto specification.
tq j101
here u go. dug this up for u. a very good write up by our fellow member.
http://www.zerotohundred.com/newforums/honda/197010-lsd-things-i-found-out-about-lsd.html
if luck is on your side, u can still get d plug n play, LSD-equipped YS1 tranny for your teg but the price is not as cheap as 5 years ago.
S4C tranny is another option if u dare to spend your bucks for the labor as the conversion from cable to hydraulic clutch system gonna costs u more.
if i were u, i would just use any manual 1st gen vtecs gearbox, enjoy my ride without all the headaches and be happy about it.
go for ys1. less headache. just pnp. if use EK9 gearbox, u will suffer during and after conversion.
but ys1 got optional rite,LSD n witout LSD.. its from da8 cable clutch,how 2 know LSD n no LSD??
J1 from da6 ratio is same as ek9 ratio final drive 4.4 juz witout LSD la... ermm..
easiest way to confirm is to remove both driveshafts and look through the driveshafts holes in the transmission. if you can see straight through its an lsd equiped gearbox.
OR
1. set the parking brake and block the rear wheels.
2. raise the front of the car, and support it with
safety stands in the proper locations.
3. with the engine off, shift the transmission into 1st
gear.
4. rotate either front wheel by hand and check that
the other wheel rotates in the opposite direction.
OR
http://www.ff-squad.com/tech/lsd/lsd.check.jpg
asking 2 all sifu.... if i want to swap head 1 set to big vtec or b16b head coz mine is small vtec.. wut should i do??got a lot of job??need rewire it back??or juz pnp???
