God has better things to do with his time than to care about whether it's chamber or camber... ;) don use his name on small things like this k? ;)
*cheers*
*cheers*
145fan said:hello all....
for the love of god...it's CAMBER la, not chamber!!!!!
BLaCkHoWLiNG said:God has better things to do with his time than to care about whether it's chamber or camber... ;) don use his name on small things like this k? ;)
*cheers*
lonewolf said:anyway..why does this CAMBER nuts so important. to my understanding..assuming i hava new car...if i don't need to adjust the CAMBER...then..i can just use the stock nuts...if i wan to change the CAMBER settings..then i oni need to change to the ADJUSTABLE CAMBER nuts...am i right or wrong?.. what i found out is...as long your car doesn't have an adjustable nuts..no matter which tyre shop you go..most of them will ask u to change..a piece of nut RM30..why are this nuts so expensive?..
jasonchan said:the shop in sunway is KIN Alignment...dont go there...!:angry_smile:
Duke Red said:wah serious ah? i always go there ler. i'm not taking sides but i wish to draw a distinction between, "NEED to change" and "BETTER to change". i don't normally like to wait till something goes wrong before fixing it ler. if the mechanic can tell me that something will go wrong soon, i'd rather fix it on the spot. some people may think of that as cheating lah i suppose. anyway maybe you're right and i've been cheated all this while ler:cry_smile: will get a 2nd opinion next time.
normality78 said:not true bro. Even less thn 1 year, absorber can leak also. depends on how u treat ur car and also production fault.
Duke Red said:Don't know what car you're driving but I used to own a Waja. My front left absorber died after about a year and I don't exactly drive in the WRC.
Kyogezsho said:yeah but then again my car i only drive in subang areas plus not even 15000milestone wor
dat fella say both side leaking .. i was like wtf . then i went to service center and ask ... they open da rims and check .. noting found ..
TheFalcon said:if u drive around that SS19 area and the road construction sites outside SS17... confirm rosak wan... so damn bumpy
jasonchan said:try the old road to perak through sabak bernam there..the road even worst..
