clutch adjustments?
Satria racer
Pahang Kuantan
sry bout the noobie q...
but.. as we all know, clutch can be adjusted from high to low..
btw, which is better?
i made mine extremely low.. and i tend to jerk alot after changing gears...
susah...
high/low for better pickup/less jerk/smooth/fc better/worse??
opinion?
thxz
release clucth padel before 1/2 way can move ur car is the best position.
not too low, not too high... too high o too low can cause ur clutch to burn... then u need more $$$$, y want to trouble ur wallet bro.... muahahhah i agree wit u boyzone... around 1/2 o alittle lower will b the best setup... :biggrin:
car manufacturers have set standards in stock cars, we're driving general daily drives. dev have good guidance there, let it be stock level.
nah.........taken from EXEDY installation note.
"Perform any clutch adjustments to vehicle manufacturer’s specifications and always reset the clutch master cylinder push rod to obtain comfortable pedal release position​
(clutch taking up as close as possible to the floor, this prevents clutch shudder and in most cases preferred by vehicle drivers). Keep in mind that the diaphragm tip position has changed with the installation of the new clutch."
