- Joined
- Jun 30, 2008
- Messages
- 1,493
- Points
- 1,648
Exedy products, recognized globally as a premium brand, are supplierd to demestic and overseas automovile manufacturers. Exedy engineering expertise and high level of quality assist these vehincle makers to manufacture quality automobiles. Racing clutches incorporate advanced technologies in which Exedy has developed over time as a Clutch Specialist.
Exedy OEM replacement Clutch
Standard OEM replacement kits include the highest quality cover assemblies, clutch discs, and release bearings packaged in the distinctive EXEDY silver and blue kit box. With advanced dampening mechanisms, premium quality friction facings, and high quality cover assemblies, EXEDY clutch kits guarantee correct fit and function every time.
Rm180.00-400.00
Exedy Stage 1 Single Sport Series
Exedy Stage 1 in the Single Sports Series comprises an EXEDY sports cover assembly, Sports Organic (SO) clutch disc and release bearing.
The sports cover assembly boasts higher clamp loads, spheroidal graphite pressure plate castings and additional drive straps are utilized to prevent pressure plate casting failure at high RPM.
The Sports Organic disc features a premium friction material for superior durability and engagement characteristics as well as high rate damper springs to handle increased torque.
The Exedy Organic Clutch Kit is Exedy's Stage 1 Clutch Kit and offers extra holding power for cars that produce higher torque than from the factory. The Exedy Organic Clutch Kit is highly recommended for cars that are daily driven and where comfort is an issue. The pedal will feel slightly stiffer than stock, but comfort and feel are key.
Additional Information
EXEDY racing clutches are fitted with premium organic friction materials and are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use.
The drivability will be similar to a regular clutch, however drivers may experience increased pedal effort, slight shudder and increased cabin noise due to the performance characteristics of the clutch. All of our clutch discs have high capacity sprung centre dampers to reduce the drivetrain shock and impact.
Rm900.00-1800.00
Exedy Stage 2 Single Sport Series
Stage 2 in the Single Sports Series comprises an EXEDY sports cover assembly and either a Race Ceramic (RC) or a Sports Ceramic (SC) Disc.
The Race Ceramic disc features a unique metal button configuration designed specifically for circuit racing applications. The disc also features a thinner design profile resulting in lower inertia and therefore reduced shift effort. The Race Cerermic disc is made from lightweight components helping to reduce wear and tear on the transmission synchromesh.
The Sports Ceramic disc possesses many of the Race Ceramic disc features and has been specifically developed for use by professional drift, circuit, rally and drag racers.
IMPORTANT: With any ceramic button clutch system, there will be some compromise of start-up driveability when compared to a standard clutch (chatter on light throttle, low RPM start-up) in addition to an increase in cabin/transmission noise. This characteristic is generally deemed acceptable in modified performance cars. Drivers of vehicles fitted with cerametallic clutches on the street should be warned not to ride the clutch or try to reduce the chatter as this will greatly increase the wear rate. The above information should be used as a guide only, please consult your Exedy distributor if further advice is required.
Rm800.00-1500.00
Exedy Hyper Metal - Single Plate Clutch
The EXEDY HYPER SINGLE CLUTCH is a new generation clutch set for light to moderately tuned vehicles up to 400 HP. The EXEDY Hyper Single Clutch is ideal for limited street driving and road circuit cars. The EXEDY Hyper Single Clutch has high torque capacity and a special lightweight design to reduce the clutch disc inertia.
LIGHT WEIGHT & LOW INERTIA DESIGN
- High friction coefficient, low wear, and a special heat resistant material (T5001) has been developed enabling clutch size to be reduced and have increased durability.
- Improved durability by strong small damper disc, especially re-designed for hyper single clutch.
-Disc inertia level is less than OEM clutch for improved shift response for fast gear changes, especially in racing applications.
DIAPHRAM SPRING TECHNOLOGY FOR LONG LIFE & HIGH EFFICIENCY
- Leading technology of clutch diaphragm spring and original design superior material using a special heat treatment process, which will result in a high durability level, and prevent heat deflection, loss of clamp load, and heavy pedal effort.
- Long life and improved clutch operation due to original design for hyper single clutch.
STRAP DRIVE TYPE PRESSURE PLATE FUNCTION
- Improved clutch disengagement. (Pressure plate is forcibly separated from facing surface by strap plate)
- Prevent no-disengagement problem caused by the heat deformation of pressure plate.
- Prevent the peculiar rattle noise of lug drive type clutch.
Rm3000.00++
Exedy Hyper Metal - Twin Plate Clutch
Exedy Street/Race Multi Twin Plate clutch designed for high torque and high performance engines
- The EXEDY Street / Race Twin Plate Clutch is designed for high torque capacity with "reasonable" streetability.
- The friction facing material is cerametallic to bundle the abuse of highly modified engines.
- Featuring a single spring damper for both discs, this clutch design has strap lift and drive for both the pressure plate and the intermediate plate.
- A patented system evenly lifts both the main pressure plate and the intermediate plate providing a "clean" release for steetability.
- The EXEDY Street / Race Twin Plate Clutch also includes a lightweight billet chrome moly steel flywheel for maximum performance.
- Again, with all cerametallic clutch systems, some chatter should be expected on low rpm start ups.
Rm4000.00++
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newforums/engine-and-performance/322721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newforums/engine-and-performance/341350-wts-works-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
