Ah...that explained it. I thought you are suggesting to boost 0.3-0.5bar with a size 4 turbo. So why are you selling it? Come out show us your car la...can test with newly tuned high cam ET dragster
Kelisa R - MJz said:Oh... My brother say wo... If your turbo kit system can win stock Kelisa... He want buy your turbo kit... You want come to drag ar??
et5828 said:if i had extra money i will brought it and drag with u
don be so mean la mjz
logically any turbokit can simply outrun a stock kelisa
bro..u are using 13" rims i'm using 14"
we swap and see...then i can bet i can win u with no sweat
i'm just tryin to clear things up...no offence k
d3ftones said:stock=not even a single mod ? try to outrun any kancil L2 std 0.7 bar and 1 bar first bro.mine has taken out..no offense. if your ride is same like kelisa187 ride,than u have something.
sorry but i think even 187 mentioned that he is no fight for those highly moded L2s...not 0.7bar..but much higher...
boosting using a larger turbo of course sounds like a good deal...but the factor of lag is a big problem...with larger turbos, u would be left with a much smaller power band unless u upped the rev limiter...how much does urs start spooling???
d3ftones said:if u're really serious,i will ask my mechanic.your budget?
d3ftones said:it;s bigger than any L2,L5,L9 turbine which kick in the boost early sumtimes u didn't feel the lag..but sacrifice the boost supply at high rpm.
while mine kick in at 3200~3500rpm and boost supplied until 7000rpm.acceleration or top speed...it depends on how u drive your car. if u launching at 3500rpm to 4000rpm at 1st gear,then u'll eliminate the lag. big turbine is good for top speed..if im not mistaken.
SuPeRtEc88 said:seem there is no any drag test liao.....sein ar
SuPeRtEc88 said:http://img.photobucket.com/albums/v314/d3ftones/zeroto100/c32925b4.jpg
as i saw there is RHB52 comp housing n 9R exhaust housing(not enough air flow), normally rev untill 6000rpm, hp will drop after this, juz curious how to gain 95hp, EJ-DE bolt-on turbo without p&p n so on?
d3ftones said:firstly,it's not RHB52.
waa,u sure a sifu la from that 'clear' pic u know the exhaust housing..and also u know how will the dyno chart going to be >drop after 6000rpm on EJ-DE engine..that's pretty cool.
btw,95hp is not my car..dat guy using custom manifold,L5 turbokit,safc,0.5bar that's all.
**** item sold **** :)
