Car suddenly die off while driving
alex9218
Sibu, Sarawak
Help! The car just die off while slowing down. The car need to crank for fews time to startup. It's seem like lost compression/not enough fuel supply. Already replaced spark plugs, plug cable and fuel filter as well. I'm driving Mira 12V carbie engine.
happen to me b4..
perdana: the sensor kong..
putra: alternator kong
it might be something else.. but try to check these 2..
Me is coz alternator kong....
but if alternator kong....the battery light indicator will go off b4 engine dies off...
alternator just replaced. Anything else need to check?
check throttle-body..polish it or change it or may be problem due to rpm sensor...
my experience on my ford car happen same thing....throttle-body problem.
vr4 turbo also samething...rpm sensor changed and problem solved.
check fuel pump...u remove d petrol supply hose at engine bay there.....see got petrol come out o not while u ON d key...if no petrol come out tat mean fuel pump rosak.....because there is no petrol supply from ur petrol tank to engine
i agree...problem may due to fuel pump also..no fuel supply ofcouse engine goes off.
Errr carbie engine no trottle body guaaa???
Just go owrk shop servis carbie lohhh..
But mont reason maybe is distributor lehh i think....u is eletrick or contact point 1???
carb no throttle body ? hahaha now i know
now i realize im still a n00b lol
haha... happened to be before... i didnt realise my engine went off till i turn a corner... coz power steering oni activated when engine turned on... start back da engine, kinda choked a little... giv some rev, choked and mati again... second time restart da engine rev till vr high, crawled to da nearest workshop... foreman say one of my spark plug kong adi... den have to change all... cis, money hilang again....
Carbie just serviced. Hmn, i'm using the electric one.
yo...too lazy to read the other posts but anyway...here goes.....i hv a pretty similar situation like u. i can't turn on my a/c while driving. because if i free gear or idle with a/c on, my engine dies. it's still currently happening.....i knw whats the prob. if urs is a fuel injection, then it's ur throttle body or the injection head's auto-choke. it's bcoz the auto-choke can't grip the injection "gears" properly, that's y it dies. so, maybe u can go check ur throttle body and ur injection head.
and while starting ur car, well, could be battery and could be alternator coz the battery depends on the alternators charging....u can check that out too....
y am i not doing anything to repair my prob??? simple.....i am changing engine next week.....:D
cheers
New Posts
