Hi, How to test whether the 1 Farad caps falty or not? how long will 1 Farad caps hold the charge? after disconnect the terminal of my caps, the voltage display instantly drop, is it normal? What is the the red LED and Green LED for? Thanks.
the displayed voltage will drop everytime u off ur ignition keys too.
last time when i install my cap, i notice once the wire taken off voltage will drop
too. then it auto off. but that doesn't mean it has fully discharged. u need
to discharge b4 storing it.
But, within 10 sec after disconnect the cable, not only the voltage instantly drop, it can only light up the 12v 5watts (very small, gauge bulb) less than 2 sec, not bright tho.... test with digital volt meter, it shows 0 volt. it just looks like the caps isn't holding any charges. or was it normal? why i'm so 'sueh' bought this caps..
ermm.... i was given a little small bulb for discharge and charging...
it only takes few seconds to charge and discharge also. i think
that is normal tough.
need to ask those who study electrical. i also not sure about this.
I've searched through lot of sources and seems like i do not get anything out there, so i've came to conclusion to open a thread and hope sifu out there can help me out..
The Detroit Auto Show is just around the corner and one of the most anticipated unveilings will be of Hyundai’s new sports coupe, the Veloster. The Korean carmaker has just released a teaser video and a microsite...
While speculation is the fuel of the internet that we can’t live without, overkill is a common problem that the rumour mill can’t find a balance with. Topic in...
