Camber settings
bernardyeo
Just want to ask what camber settings do you all use. How is the tyre wear like? For daily driving, what do you recommend?:driver:
Front
Camber: -1.5
Toe In/Out: 0.5 Toe In
Caster: Stock
Rear
Camber: -1.0
this is mine..using Bilstein e9 with e8mr set-ups...superb so far...
not sure whether it'll suit CPNA chasis or not la Bern!
So the tyre wear is still uniform even on a negative 1.5 degree camber? I would imagine the inner sides of the tyres would wear out really fast. But definitely would have less body roll when cornering.
What's the advantage of adjusting the toe?
Okay, I found the answers from the Mitsubishi Lancer Register Evo Buyer's Guide.
bernardyeo, please share..... what's the optimum setting ?
It's a lot to share, so download the document here. Take note of pages 130 to 136.
http://www.lancerregister.com/downloads/MLR%20Evo%20Buyers%20Guide%20v1_00.pdf
I think it depends on individual driving styles and requirements. If you don't do hard cornering and spend most time along the highways, you don't need -2.0 degrees. Because it will kill your tyres. But if you are a serious autocrosser, you probably need -2.5 degrees.
