- Joined
- Jul 4, 2006
- Messages
- 1,138
- Points
- 1,648
still the same as mentioned above. the built in crossover i din use as i full pass it to let the filtering be done by my alpine x-ver. however the parametric Q setting for the bass is midwide,mid-normal-high-normal. sub output frequency set at 80hz
alpine crossover setting for tweeter 7.5khz, mid 800hz....amp set to full pass.
my rear output i connect direct to my 2channel amp as it is my 6" midbass. however the amp is abit overpowering although i turn all the knobs to minimum. have to use fader control at HU to cut down the rear volume.
sub woofer is connected HU-parametric equalizer (most common pl out there call pre-amp) line out at *front out* as i wanna control the 50hz ,125hz ...i can opt for the subwoofer line out but i will be only limited for the 60hz and 90hz jumper setting,and sub volume only. thats why i wire my para EQ tis way and direct to my monoblock. im now still considering whether to take up the offer to buy the scope which is made in taiwan for a mere rm1450 only.. i tested it and found out it is sufficient for my normal usage to set the max amp gain,hu output and anything u wish to check distortion happening at which level. it relli make things easier wit a scope as what you need to do after u wire your speakers after you set your gain is just to turn down the volume to match your speakers
