hey guys, after BOT for 2 months, problem arised again.
For your information waja have 2 ignition coil which connected to the spark plug. My car was having dificulty to start after long run in highway and get diagnosed that 1 side of the ignition coil malfunction. Today my car have the same problem again, and the foreman told me the same side of the ignition coil spoilt.
He suspect is the turbo causing the ignition coil malfunction. Anyone have any idea what is it going on? Could it be the tuning problem? or engine over heated problem?
well ah ren
if u using emanage on the 4g18.
last time i measured a lancer 4g18 wif a scope i found the ignition coil signal is around 10Vp. the emanage can only set to either 5v or 12v. make sure u update the firmware to the latest version. this can be found at mohdparts.com. they reportedly have the latest fix for ig coil problems.
over heating from long distance running might also be a cause.
good luck
