Astronomy anyone? :p
junsupra
Malaysia
Planet Mars will be the brightest in the night sky starting August.
It will look as large as the full moon to the naked eye.
This will cultimate on August 27th when Mars comes within 34.65M miles of
Earth.
Be sure to watch the sky on August 27th at 12:30 am.
It will look like the Earth has 2 moons.
The next time Mars may come this close is in 2287.
Share this with ur friends as No oNE ALIVE ToDAY will ever see this!!!
Helping out junsupra's small article:
Approaching Mars
Earth and Mars are converging for a close encounter in August. The red planet is already an appealing target for sky watchers.
June 18, 2003: Count slowly: one one-thousand, two one-thousand, three one-thousand.... You just got about 30 km closer to the planet Mars.
Earth and Mars are rapidly converging. On August 27, 2003--the date of closest approach--the two worlds will be 56 million km apart. That's a long way by Earth standards, but only a short distance on the scale of the solar system. NASA, the European Space Agency and Japan are all sending spacecraft to Mars this year. It's a good time to go.
Right: This is what Mars looked like through the eye piece of an 8" telescope on June 11th. Image credit: Ron Wayman of Tampa, FL.
Between now and August, Mars will brighten until it "blazes forth against the dark background of space with a splendor that outshines Sirius and rivals the giant Jupiter himself." Astronomer Percival Lowell, who famously mapped the canals of Mars, wrote those words to describe the planet during a similar close encounter in the 19th century.
Already Mars is eye-catching. You can see it this month in the morning sky--bright, steady and remarkably red. Only Venus near the sun is brighter.
Amateur astronomers looking through backyard telescopes have reported in recent days great views of Mars's south polar cap. Made of frozen water and carbon dioxide ("dry ice"), it reflects sunlight well. "I can see the polar ice vividly using my 8-inch telescope," says Ron Wayman of Tampa, Florida. He's also spotted "some faint darker-shaded areas on the surface."
Such markings will become clearer in the weeks ahead. On June 1st Mars was 12.5 arcseconds across and it glowed like a -1st magnitude star. On August 27th it will be twice as wide (25 arcseconds) and six times brighter (magnitude -2.9).
Much has been made of the fact that the August 27th encounter with Mars is the closest in some 60,000 years. Neanderthals were the last to observe Mars so favorably placed. This is true. It's also a bit of hype. Mars and Earth have been almost this close many times in recent history.
Some examples: Aug. 23, 1924; Aug. 18, 1845; Aug. 13, 1766. In each case Mars and Earth were approximately 56 million km apart.
Astronomers call these close encounters "perihelic oppositions." Perihelic means Mars is near perihelion--its closest approach to the sun. (The orbit of Mars, like that of all planets, is an ellipse, so the distance between the sun and Mars varies.) Opposition means that the sun, Earth and Mars are in a straight line with Earth in the middle. Mars and the sun are on opposite sides of the sky. When Mars is at opposition and at perihelion--at the same time--it is very close to Earth.
August 27th is indeed the best perihelic opposition since the days of the Neanderthals, but it scarcely differs from other more recent ones. That's fine because all perihelic oppositions of Mars are spectacular.
Mars is a morning planet now. You have to wake up early to see it. Soon, though, it will be more conveniently placed. By mid-July Mars will rise in the east around 11 p.m. local time. In late August it will appear as soon as the sun sets. It won't be long before everyone can see Mars at a civilized hour.
We'll be telling more stories about Mars in the weeks ahead. This one, though, is finished. Did you make it to the end? Congratulations! You're now 2000 km closer to Mars.
MARS BIODATA
Orbital characteristics (Epoch J2000)[1]
Semi-major axis 227,936,637 km (141,632,976 mi)
1.523 662 31 AU
Orbital circumference 1,429,000,000 km (887,900,000 mi)
9.553 AU
Eccentricity 0.093 412 33
Perihelion 206,644,545 km (128,402,967 mi)
1.381 333 46 AU
Aphelion 249,228,730 km (154.863,553 mi)
1.665 991 16 AU
Orbital period 686.9600 d
(1.8808 a)
Synodic period 779.96 d
(2.135 a)
Avg. Orbital Speed 24.077 km/s (53,859 mi/h)
Max. Orbital Speed 26.499 km/s (59,277 mi/h)
Min. Orbital Speed 21.972 km/s (49,150 mi/h)
Inclination 1.850 61°
(5.65° to Sun's equator)
Longitude of the
ascending node 49.578 54°
Argument of the
perihelion 286.462 30°
Number of natural satellites 2
Distance from Sun 1.52 AU
Physical characteristics
Equatorial diameter 6,804.9 km (4228.4 mi)
(0.533 Earths)
Polar diameter 6,754.8 km (4197.2 mi)
(0.531 Earths)
Oblateness 0.007 36
Surface area 1.448×108 km2 55,907,000 square miles (144 798 465 square kilometers)
(0.284 Earths)
Volume 1.6318×1011 km3
(0.151 Earths)
Mass 6.4185×1023 kg
(0.107 Earths)
Mean density 3.934 g/cm3
Equatorial gravity 3.69 m/s2
(0.376g)
Escape velocity 5.027 km/s (11,245 mi/h)
Rotation period 1.025 957 d
(24.622 962 h)
Rotation velocity 868.22 km/h (539.49 mi/h)
(at the equator)
Axial tilt 25.19°
Right ascension
of North pole 317.681 43°
(21 h 10 min 44 s)
Declination 52.886 50°
Albedo 0.15
Surface temp.
- min
- mean
- max
133 K (−140 °C)
210 K (−63 °C)
293 K (20 °C)
Adjective Martian
Atmospheric characteristics
Atmospheric pressure 0.7–0.9 kPa
Carbon dioxide 95.32%
Nitrogen 2.7%
Argon 1.6%
Oxygen 0.2%
Carbon monoxide 0.07%
Water vapor 0.03%
Nitric oxide 0.01%
Neon 2.5 ppm
Krypton 300 ppb
Xenon 80 ppb
Ozone 30 ppb
Methane 10.5 ppb
Article source : www.nasa.gov
ure welcome jun .. :) anyway im waiting too see dis event! .. even my grandson wont be alive when this event repeats !
take some pics yeah..........
i might not be awake than.........
kekekeke
boon damm hamsap la u.. hehehehe
u refering to poc or mars?
duh~~~
Mars and Moons lar of cos..........
hahaha.....
*wondering who hamsap*
which guy in this world not hamsap leh? *wonder..
back to the topic after jun tapau us in lucky.. kekekeke
SORRY TO LET U GUYS DOWN!
The Red Planet is about to be spectacular!
This month and next, Earth is catching up with Mars in an encounter that will culminate in the closest approach between the two planets in recorded history. The next time Mars may come this close is in 2287. Due to the way Jupiter's gravity tugs on Mars and perturbs its orbit, astronomers can only be certain that Mars has not come this close to Earth in the Last 5,000 years, but it may be as long as 60,000 years before it happens again.
The encounter will culminate on August 27th when Mars comes to within 34,649,589 miles of Earth and will be (next to the moon) the brightest object in the night sky. It will attain a magnitude of -2.9 and will appear 25.11 arc seconds wide. At a modest 75-power magnification
Mars will look as large as the full moon to the naked eye.
Mars will be easy to spot. At the beginning of August it will rise in the east at 10p.m. and reach its azimuth at about 3 a.m.
By the end of August when the two planets are closest, Mars will rise at nightfall and reach its highest point in the sky at 12:30a.m. That's pretty convenient to see something that no human being has seen in recorded history. So, mark your calendar at the beginning of August to see Mars grow progressively brighter and brighter throughout the month.
Share this with your children and grandchildren.
NO ONE ALIVE TODAY WILL EVER SEE THIS AGAIN
Comments: I labeled this rumor "true" when it first began circulating in the summer of 2003, "outdated" when it went around again in 2005, and just plain "false" when it appeared for the third time in 2006. How many times can a "once in a lifetime" event occur?
The oscillating orbits of Mars and Earth did, in fact, bring the two planets closer together on August 27, 2003 than at any other time during the past 50,000 years. Though Mars never actually appeared "as large as the full moon" -- not even close -- for a time it was indeed the brightest object in the night sky.
In October 2005 another well-publicized "close encounter" occured, though in that case the planets were about 13 million kilometers further apart than during the 2003 event.
Nothing so spectacular is predicted for 2006.
THE DREAM IS OVER!
errrmm : http://urbanlegends.about.com/library/bl_mars_encounter_2006.htm
Close Encounter with Mars (2006 Version)
Netlore Archive: 2006 email hoax repeats three-year-old claim that during the month of August the orbits of Mars and Earth will bring the two planets closer together than they have ever been in recorded history
Description: Email hoax
Circulating since: July 2006 (this version)
Status: False
CASE CLOSED!
Write your reply...
