Any time engine jerk/semput semput dan check engine light up short while
Mat Indera
Feb 26, 2014
26
503
My wira 4g93t with evo3 air flow sensor, td05 turbo, 510cc, evo3 rechip ecu for 2 bar, afr, 255l fuel pump. All inside/outside upgraded. Run smoothly for a year. I set max for 1.2 bar boost only. Last 3 days ago suddently engine check light flashing sometime than dissappear. Yesterday the engine become jerk @ semput semput for short while and back to normal again. It happen at any rpm. When jerk/semput check engine flashing shortwhile. Clearly to me it disturb the fuel and/or ignition system. Fuel filter and fuel pump rule out- aready checked.
Sometime I can drive for an hour with out a problem. Sometime it happen 2-3 time within 5 minutes. Jerking/semput shortwhile than back to normal again.
Guys can you help?.
30,002
Tried ECU scan already? Check engine light comes on can be many things. Even when I wash VR engine bay, sometimes check engine comes on but no problem driving. Then after engine heats up the light goes away....:rolleyes:
Mat Indera
26
503
Will try but in the workshop during idling everything ok. No check light and idling smooth. Since 3-4 days raining everyday and car driving during raining. Want to wait shinny and hot day and see what happen. Just know cleaning air filter and air flow sensor/ socket.
30,002
Yup, can be dirty sensors also. O2 sensor going also can have check light on and off....
7,514
just clean your MAF sensor....usually that would be the cause....
pac_jb
131
518
I had the same problem last time, mine was the maf sensor connector was lose, so I bought long cable tie and tied up the maf connector and try to check ur spark plug
Mat Indera
26
503
yesterday I drive for another 5 hours, engine ok. The work I m doing are cleaning MAF/ socket, cleaning air filter, re-tighten the cam sensor socket, re-tighten loose hose clamp at turbo inlet . I dont know which one is a real problem.
Hello guys.
I can't find any thread on NGV. Any idea about NGV?
What are the advantages/disadvantages of NGV vs Petrol/Diesel?
From what I know NGV price is cheap, which means by installing NGV tank into our car, we are gonna save lots of money. But bearing in mind, the tank is heavy which will cause the fuel consumption higher. We are also gonna sacrifice our boot space..
But currently lots of NGV stations are being opened...what will happen if all new Proton and Perodua vehicles use...
