aircond got a problem
baq
penang
need help
need some body help me,When i start the engine and open the aircond ,have sound from engine can i know what the promblemm..
new user :rock:
juz go to aircond shop. let them check. check is free maa...
if u want to repair, ask for a quote how much. verbal will do. then come back here and ask whether u shud pay such price or possible to get lower.
if noise comes from inside it must be expansion valve faulty. not so costly.
if from outside (engine compartment) then there are many possibilities.
what i could think of are..
1. a/cond condenser fan is not running smoothly. its causing the noise and as it cant blow cool air to the condenser, acond also not cold.
2. compressor. he he prepare to spend some money. but it also depends on wat is actual problem and whether repairable or not and also depends on the model.
i) if problem with magnetic clutch, just change the clutch. some model comes separate from compressor. some model comes fixed.
ii) if problem with compressor internals, dont simply believe. ask 1st whether can overhaul or not. overhaul kit is about RM80 only. a gud a/cond shop will answer "we can open it and check 1st. if can repair, we repair. if open but condition very bad, u have no choice".
* it took 3 times to overhaul for my car compressor at my a/cond shop. but after 1 year, the compresor is running good.
certain a/cond shop already have reconditioned compressor, so juz remove the old one and change. exterior looks does not matter. its what on the inside that matters.
pls describe wat make is ur car. maybe some of us had experienced similar prob and know wat is the actual symptom.
Make sure u ask around or go to trusty aircond shop. Few of them are doing con job..asking to change this and that.
my compressor leak the oil and gas when air cond engaged. the mechanic said it was leak at the center seal, and he said no spare part for that. My car (wira 1.5) using the compressor from mitsubishi engine. I'm getting headache, coz this one is my 4th compressor i change. Could you recommend me which shop can do the compressor repair?
Normaly compressor has to be change if its leaking of gas or what ever.Try not to buy thos kedai potong 1s.Most of it not in good condition.Try yo get the recond 1s and make sure the mech orders in front of u and comes wrap in plastik in a box.Normaly there is a few months warranty.
Life to ride,ride to DIE>>>>>>>>>>>>>>
Oh!!!! Thats bad.So far for me no problem.Maybe the mech tipu u or its time to change to a new one.Even u go to EON Sc they will recomand u to buy the recond ones becouse is all new inside.Thats what they always tell me......
my acond shop recommended me to change to a general type compressor. which can be overhauled when leak.
just extra cost of changing the compressor bracket. at least, the cost is lesser than changing a new compressor afterall.
got to few aircond shops and compare their opinions and prices. bring a fren if necessary.
