ADC
ad resort still can legally 'upgrade' to SR20DET? or SR20DE.
gearbok: have u check the gear bushing ???????
nickster1982: for the makan stuff , u give me a buzz then i will come out. for time to makan i wont miss hahahahahahaha.........
lot: yes , u can upgrade to sr20DET LEGALLY !! is confirm.
gearbok
which gear kicking out probably shift fork or synchro koyak. sr20de lama famous for chewing out 2-3-5.
lot said:
gearbok
my frens car been into sr20det , but i didnt hear him got trouble on 2-3-5 :confused:. frens from cut chop also didnt mention.if sr20det no problem i presume sr20de also the same(correct me if wrong)
hi all.....
i think adr is more power if use sr20/det, but not sure bout handling.........
am i right julie?
http://myspace-838.vo.llnwd.net/00121/83/82/121312838_m.jpg
hehe...i think u right andy...
julie ZZzzZZzzzZz
http://myspace-392.vo.llnwd.net/00143/29/31/143071392_m.jpg
hi guy need ur advice
Overheating problem
that day my radiator has a leaking at a bottom plastic part and i change to y10 radiator from japan half thinner than local but made from alumunium. After travel about 50km the temp needle just shot up beyond the red and then this cause my water hose koyak, lucky it on ending part so i still can cut then stretch the hose, i topup a new water with coolant then taking hiway for cruising without traffic, the again when i reach kl i was stuck in traffic then temp needle just shot up again beyond the red line, i just close my eyes and keep up driving because my home is very nearby. When i reach home, i check another hose is koyak, now the water hose from thermostat (under the carbie). A day later, i replace a new hose the drive about 20 min then again the needle almost reach the red line. My question is that overheating effect my water pump/thermostate, how to detect water pump not working?
tahun 89-91 punya......very popular fix 5th gear pop out repair kit in America.
Overheating problem
u sure your 'new' radiator not clogged? shoulda rebuilt your old radiator.......probably the same price as your 'new' radiator.
step 1
check flow of 'new' radiator if OK
step 2
check thermostat is free aka not jammed. open up at appropriate temperature.
step 3
your fans working or not?
step 4
replace all hoses there are a total of 4 (TCM told me) but I replaced a total of 3 only. 2 big 1 small behind air intake
BTW I'm using GA16DE fuel injection.
i pouring water from top holes and water access at the bottom (i open the hose) is that flow okay?
normally when do cold start, fan will start running at hot temp (aircond off), if the fan working that mean termostate also fine, right?
if the termostate fine that mean waterpump also fine ka? please confirm this
booth fans fine
someone told me, a radiator has a life span for plastic cover top n bottom, 80k km for wira, is that true?
thank
hye...
BOB .. try dont use thermostat ... see also ur fan .. both air cond n radiator fan..
Insya Allah ...
if u car on diver it ok... but if on jammed... masak ... but try 1st ...
Cargas...
pink_ad said:
hi all.....
am i right julie?
i dun dare to say i am right........ eberyone have their own opinion. SR20det on y10 is good at torque(pickup)but due to the car design is a bit high(for me) that makes this car in 100% good handling. one more thing , y10 runs on an axle and the rear cannot adjust camber, in theory have bad handling. due to all car expert in malaysia, i think they all have their own way to overcome this !! me not ZZZzzzzZZZzzzZZZz...... just busy of my new work. less time to online
i dun know how true is it, but i think is the way ppl drive it. actualy u miss out one thing. the weather in US and here is diff. u cant relate it together as popular. American ppl love big horsepower with fully upgrade engine (stage 2,or stage 3). v here usually just up boost the ride. is diff.....
booth fans fine
thank
bob, actually i m not too sure bout ur case. but "lot idea is great. y not u try to fill up the radiator(with newspaper under the engine) n check the water tomolo morning. the best is get a pressure tester and check. coz by using this, it can tell u where is the exact place leaking. but now i think leaking is it matter or overheating is matter. pls throw away the thermostat(rubbish) cold start in Malaysia is fine(not that cold also mah.........) ok, let me tell u the worse case u might be dealing is waterpump. the hose i think is ok guah......
very hard to guess, i think u need to get the expert to look for the troubles. without checking ur ride, talking here blah blah blah ...............everyone is guessing oni. me also guessing.
PS:radiator pressure tester really can solve ur problem.
thermostat rubbish ... i heard about that also
yesterday i do a cold start (aircond off) waited about 15 min the fan still not working and i knocked the thermostat housing then only fan is working, confirm thermostat is damage, later i will try remove the thermostat and see how.
if i throw this thing that means my cooling passage have no block, water circling all the time?
if plan A doesn't working i will do pressure test
wah julie no more in pandan ka?
how the ledang trip, anyone going?
waaaa..... it's really been a long time didn't log here...
still remember me ker?? sylverAD leh..
how's u guy?? ok ker?? theheheheheh...
me no more working in pandan. now working in pj. if come to pj give me a call lol. hopefully Plan A works. bout ledang i am not sure who going but i know i am not going.
k_typeSILVER: if u dun mention u are silverAD then no one will know . now everyone knows u . hi hi to a long long fren
Sylver - Of coz remember you. From Ipoh mah and always MIA but appear again suddenly. Hope u din forget me la. :D
Bob - About your fan, ketuk abit only jalan, I had the same problem la but temp didnt go high. But I just change the fan from kedai potong RM30, voila! Ok dy plak.
