- Joined
- Apr 3, 2009
- Messages
- 186
- Points
- 1,518
Thermostat going to kaput..
i heard there are a three thermostat in an engine. true? :hmmmm:
if yes, which one could be the main culprit.
darn it.. change the thermostat already, and yet the water temp reading rise... what is happening here!
water pump ok ka bro?..
75 to 90deg C is quite common... if you want it to be lower get a better flowing radiator fan and fan controller. why fan controller u ask.. because you can set it to turn earlier so that your engine will stay cooler longer. however, over cooling is another problem.
as i've mentioned and proposed... radiator fan not powerful enough during jam. how old already the stock fan motor? i've been there, done that. believe or not up to you.
also, it will be a good idea to install a water temp meter on dash to monitor water temp.
