- Joined
- Nov 15, 2003
- Messages
- 237
- Points
- 3,016
fuel pump?
u mean the fuel pump doest supply enough fuel when full acceleration?
i doubt that a bit, but ill give it a check anyway.
any other suggestion from all the gsr gurus??
fuel pump?
eventhough u didnt modified,u never knew what can happen,thats why boost meter is the 1st things people suggest to put.higher boost is possible.
but im going with lord..maybe the fuel pump,fuel filter n fuel line.
To All Sifus,
Need your guys expertise about 'Metal head gasket' wat size is suitable for GSR engine ? only upgrade VR4 intercooler, no engine modification. Boost 1.0bar . My car is doing Top Overhaul+Skimming+Serive Valve and i wondering wat size should i use for my current condition ? izit ORI gasket size 0.8mm ? My frenz told me use 1.0mm or 1.2mm. 1.5mm is too high unless need to go for high boost ? Your reply is much appreciated
what u are experiencing is bad grounding connection for your 1st injector. check your sockets and wires for bad/poor connections.
Thx for the reply
Bro...
You've stated that the problem could be a bad grounding at the 1st injector.
Any suggestion what i can do and what to look for.
Could i just tap the negative wire and connect it to the car body... Just an idea.. really trying to learn this stuff step by step:hmmmm:
best if you could visit a vehicle wireman to get it fixed for you since you roughly know what is the problem. while at that, better if you could replace all injector wires at the same time.
Similar threads | |
