ftzone..
thanks for the info. will do it tonight.
Wahahahahaha...
Ftzone...
Boost Canser................
Wanna ask about this thing.
Last night my check engine lite at low rpm ie bellow 3Krpm or 1/4 trotle and goes off at above 3.5Krpm 1/2 trotle.. slow it lite up.. is it the trotle position sensor or the T/B itself.
JB many many road blocks man.... HID exhaust dark tinted sure kena.. my friend 1 nite 2 time kena!!!!
musang,
during your check engine light right, do you feel any difference with your engine performance? it is always consistence as the problem u described?
these are the few things u may consider checking, Because all of these could trigger the check engine light.
1. ECU sockets may not be in good contact, ECU capacitors may be leaking.
2. Engine Relay (located at the rear of the radio)
3. Air Flow Socket, Wiring.
4. Crank Angle Sensor Socket. (Check for idle timing) Base timing is 5° advance.
5. Throttle Body TPS Sensor position.
6. Ignition Sockets. (Located on the right side of the intake manifold when u are facing your car) Please note these are not plug cables... but ignition sockets which is connected to the ECU.
7. O2 sensor failure.
8. Injectors failure.
That is what I can think off for now. Check whatever stuffs u think is the easiest first, gradually check to more difficult stuffs later and narrow down the possiblity.
Similar threads | |
