4G92p + mivec t/b
chiku
hi everyone... i got question regarding de title above... if i wanna install MIVEC t/b into 4g92p wwhat i need to do...??? have to change wiring harness.>?? a/c wiring harness..?? intake manifold mouth oso need to mod or not..??? thanks in advance...
did u say mivec turbo? mivec is dont have turbo it is rojak with 4g93t gsr.the wiring will be change,intake is not same.better take 4g93t half cut and mivec head
I believe what he try to say is mivec throttle body to plug in into 4g92 intake manifold.
The wiring should be same, the only different is mivec throttle body bigger means more air in...
the trottle body is bigger.. but the intake is tilll the same..
yea i know MIVEC t/b more bigger than 4g92p t/b... but de problem is a/c wiring harness not fit loor...??? can anyone suggest de w/shop to counter dis problem...
mivec tb is running with stepper motor. However, 92p is run with gear.
