4g92
alvin_4G92
why my engine (Mivec) always jerk during engine idling time, something like fuel pressure/spark doesnt supply accordingly but not happening and its running smoothly when engine rpm 1500~2000 above...
some more, i used to suspect air restriction because i had remove one of my vacuum hose which attached with fuel rail regulator and use a screw to stuck 1 side of it then test drive...everything goes smooth!!!!
that is why i suspected it...
i had change my spark plugs, fuel pump, fuel filter doesnt get well...
need assists/advises or any comments....thanks!!! :regular_smile:
what is ISC stand for? and what can i check of those injectors???
is your spark plug burn nicely? if yes lets assume ur injector got no problem.
ISC also called as stepper motor, its a small motor lies underneath ur trottle body, usually brown or black in color.
yes, i got it...
is there any possible caused by the ignition coil???
i had checked and measured the spark plug cables...everything are ok
this few days i realize something which is not possible but its happened
my a/c fan wasnt function properly even though my compressor cut in...now i already fixed my fan and it is working accordingly, my engine doesnt jerking like before...
engine
That's strange bro...after the fan being fixed...the prob is solved..
Anyway, gud for you..
ya...i felt weird either... the problem is still there but been minor , not before ... i hope to solve this
intake manifold gasket and injector O ring leak!!
recently, i found out that one of my injector's O-ring is leak and suspect the intake manifold gasket leak... so what is u guys' opinion????
bro, your car so many problem....are you buying 2nd hand?
I bought my 4g92p (2nd hand) 5 years ago...within this 5 years i alomost spend RM10k on my car......
we are pity guys...
