marcusloo3003
lol..
beztien
yeah...u can use other car air flow sensor...to me,it doesnt make any huge diff if ur car is stock...becoz wat is important is more air goin in,if same amount of air goin in,no point changin the sensor.so unless u have done major mods and u gonna get more air comin in(forced induction,upgraded TB or Intake)dun think it's necessary.maybe wil Fuel Consumption will increase too and idling gone haywire.
Miez
y dun u start with ur intake and exhaust 1st if u wanna go step by step becoz tats what is simple and kinda cheap. if u want high power increase,then why not,get ur friends stuff if its cheap. e-manage is more useful if u have done a few modification(air filter,exhaust upgrade not included).stock engine if tuned wit e-manage of course,i dare to say will have hp and tq increase but minimum. if fully wanna utilised the e-manage and at the same time extract the most out of ur mods...then its ok to install it.
hope this help....i might not reply...not alwiz have the time to reply....thks
Beiz,i have tried to use 93 ECU and the air flow,car cannot start :P hehehehe...
Miez,..do as what Mitec mention,and start from there. About E-manage,yeah doubt it help much if it is mostly stock.. Btw,what kind of cams is your friend using? How much is he selling it for? tempted to try..hahha
Heretic,should not be a problem..direct installation..Btw,what car are you using? Wira,Satria should be the same..Iswara,read somewhere might need a bit of mods on the engine mounting..
Ram,hope that will finally cure the problem..Since they have check everything..Fingers cross...
BTW,any using 92 mivec pistons in our 91? Rebore the block? is it any good..Wana change 93 block,need to replace timing belt.. So,might just wana maintain the original block..
