Well, we don't see the work he's done, only you see it up close in person. You can ask your other mechanic on his opinion, and you judge yourself whether what he's asking is fair based on the quality of work he has done. If the wiring job he did is good, soldered/crimped, heatshrink, routed properly then that should be good. If all he did is cut, twist and wire tape, wires all over the place then I'd suggest looking for another wireman.
If the plugs came with the engine, save your trouble, google the code of the plug you need, go to spare part shop and straight away buy and replace. Up to you to get copper, iridiums or NGK platinum, pretty much no difference when new, only difference is the longevity.
The wires are done and he requested more payment, which i am dissatisfied, we agreed on the said payment and now he said he spent on retrofitting something else to make the gauges all work, so needed more payment. I can say he's done a great job but only thing i detect is the electronics are not getting enough power, might be battery issue or grounding issue.
The plugs are old i can assure that, may be changing the plugs will cure the cold start issue as most turbo cars will use colder plugs.
Thanks,
Ken
