front drive grip???
Che.Det
124
front drive grip???
what should we do/improve/upgrade to have more grip ? which size of rims will help? 16inch/15inch/17ich?
grip and traction have the same meaning?
taiko answer laaaa
Che.Det
124
satria only bro,
i already have UR ARB 16mm if im not mistaken,
and bout the front chamber what kind of setup should it be?
SE86
299
474
1,563
if for daily usage dont get too much of camber..will get your tyres bald in the inner side..juz get a very less negative camber will do..
Che.Det
124
the camber must be adjust to negative la? but not so much ok.
hermmm, all around need to be adjusted? or just front?
SE86
299
474
1,563
depends on ur car bro..cause like for my car is lowered and onli front can adjust camber..so onli adjusted the front to i think -0.5 i think..not so much..so best of luck..
suspension also important. tyres also important..everything is combined and plays an important role..
SE86
299
474
1,563
yes..previously i was using -1 camber...that was on my previous tyres..now with new tyres new setting i have lessen the negative..bringing it to -0.5..tayar mahal..haha..
---------- Post added at 08:45 PM ---------- 6 hour anti-bump limit - Previous post was at 08:44 PM ----------
with negative camber i think u will get a bit quick response handling..
Che.Det
124
uish, ride not nice laaaaa, paint also not niceeeee. sad sad sad~~
w8 for money to come, and paint it with original GTI color. T_T.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
good tyre helps alot... suspension and chassis, everything do helps in giving better grip and traction...
btw, grip and traction is slightly different...
Sifoos arnd need assistance,
What are the major difference/s if I do change my siemens ECu to a MMC ECU on my 4G15??
I have one MMC injector kit in hand-if the difference not going to be alot different then it would not be worthwhile changing?
PLease enlighten me as I am new to ECU and stuffs like these!
Thanks
