Q on Oil catch tank
jiusan
I made one myself at home ,
i think it works not bad ,
material = plastic bottle , gas hose < i'am using 9mm transparent type > and sponge like thing that you often get when buying delicate items like computer internals ,
well still i wonder what is actually inside of a real oil catch tank
< the truth is i asked some big tuning expensive car shop and they told me inside was empty >
hmmm .....
and my one , i notice that oil in black begins to clog on the sponge where i insert some to the hose .
should this happen ? coz i think its catching oil rite ?
and on the bottle there are traces of oil as well ,
and also , there are water forming like boiling water there are water drops on the top of the pot , is this ok ? its due to the heat of the gas compress inside a small bottle i think .
and i'am i suffocating the engine ?
coz i driven it very long with these thing and it works well
i will submit pictures soon
hmmm .....
yeah.... there are already lotsa DIY oil catch tank. Plastic bottles are fine if u don't really mind how it looks.
From the crank/engine breather, u'll expect lotsa oil and water in vapour. Normally, they are recirculate into the intake ramp to reduce the polution. However, this will increase the carbon content within the air and also accumulation of oil/carbon to ur throttle body, valve and the combustion chamber.
So, an oil catch tank allow the crank breather air to have sufficient time to cool down and condense, so that the air thatr's recirculate into the intake ramp is somehow cleaner.
Regarding the black, it's also normal. Coil squirts onto the cylinder wall, during the combustion, the remaining oil burns together with th fuel and air and leave carbon behind. When the piston goes up again, it cleans the carbon into the oil sump. So, oil will eventually turns black even 1 day of driving. And the air from the breather contains all sort of things including oil, carbon, water, some sulphate, etc etc...
Don't worry about it, it's fine. Do removethe sponge in the hose as it will restrict the air from moving freely.
let me get this straight. i can attach a bottle or wadever container to the breather hose or there's a small metal nozzle at my engine where normally will have a rubber hose connecting to the air filter pipings. i think this nozzle is where to connect the oil catch can. correct mah? if correct then i go diy one osoz lor. hehehe.
btw, does the bottle or tank needs to be fully sealed except for the hose from engine head?
Normally, ppl don't take from the hose to the manifold.
Not necessary tightly sealed if u are nor recirculating to the intake ramp. U can just let it breath out. But make sure u close down the nipple at the intake ramp.
i have attached a pic of my engine and intake manifold area. the normal breather hose (circled in red) is attached to FITT on the right which is a valve to help control my idling when air con is turn on. is this breather hose the one that is to go to a oil catch can?
I'd chose to put it at the other breather.... At the distributor side.
other than the earth, anything else? i read somewhere that the purpose is to "catch" oil and especially water vapors from the heat generated by the engine. this in turn will help ensure better engine oil condition and thus engine moving parts movements. true? sounds logical
hmm , i've checked the oil catch "100plus" bottle again today
still the same but feel much more assured to mr speed2horizon ,
and i remove the sponge to the hose as well , actually it poops out itself haha
thanks all
A Post Every 5 Mins
hey, i had just got an L2 meter..but dunno how to connect it since my kancil 660 is less wire than this L2 meter..
i know there is some wire i dun need to connect..i had know all the wire for my kancil now..
but there is something that i dunno too...
the petrol level meter and the temperature meter i dunno how to connect... can any sifu help me?
btw, the ori kancil temp meter got 3 terminal..which is +, - and signal i think..but the L2 temp meter only got 2 terminal...anyone know how...
