BT 20v Engine check light on
hon_cs
Ipoh
Hi Guys,
This morning, my car engine light was on. Performance and rpm dropped until engine stalled. Tried couple of times to start. Yes, can start. But once i lifted foot from gas pedal, engine stalled again. Removed batt terminal to reset ecu but still the same. End up went to workshop and one forman helped me to diagnosed. Error code was air intake/vacum sensor abnormal. What forman has did
1) Swapped map sensor. Result still same.
2) Checked map sensor hose, no hole or leaking.
3) Swapped TPS sensor. Result still same.
4) End up, he used air gun blew map sensor hose that is conencted to throttle body. Check light dint showed, but rev 5-10 times, light on again and engine stalled.
5) The last thing he did was changed below item which i marked in orange color. I duno what this thing call. From workshop until now, so far so good.
After all, he told me it could be my throttle body or the part on top of injectors there dirty. He suggested me take everything out to do cleaning and the labour is Rm250. Is this the usual price? Somehow until now,i still not convince and the problem might come back. I checked on bro Chin website, but couldnt find this intake/vacum sensor.
Guys, any suggestion on this? Urgent need help here. Thx.
if i'm not mistaken, that's the one-way valve where the hot air comes out and recycled back to ur throttle body. that black pipe connected to the big vacuum pipe on the throttle body. can this actually solve that problem?
A faulty PCV won't stall your engine, especially BT that running MAP.
If PCV clog, you will get white smoke fr your emission instead.
"If you have error code but found no problem on the related sensor, or if you have problem but no error code detected - check your ECU!"
Hope this help.
thanks all sifus for the prompt replies. just tested my car again. yes engine check light appeared a while then gone. how i knw whether ecu got problem? levin818, heard you do repare ecu. can help me to check on this? if check lights on and i keep revving, can smell smelly fumes.what about if wiring issue?
lol levin always like to ask ppl to check ecu hehe
Because i only know ECU :biggrin:
Ops.. also the ayam goreng :biggrin:
---------- Post added at 08:49 PM ---------- 6 hour anti-bump limit - Previous post was at 08:35 PM ----------
Labour to completely strip down and clean the 4-throttle is around RM250. It is quite reasonable as it need at least 4hrs to do the job. However i am doubt your problem is due to dirty 4-throttle as if you have this problem you will have unusual jerking and power loss (check with Banzai he faced it before). To help you save RM250, you can try swap your ECU with your friends. If the problem also "swap" then confirm its ECU problem.
Wiring problem? Perhaps you are referring to disconnection of sensor's wire that lead to your unstable situation. However if this is true you will have check engine light continuously. But now you don't so chances of wiring problem is slim.
My suggestion is swap your ECU first before go for other options.
hi levin, yeah, that's why im not convinced what my forman suggested. i think and re-think again if the problem really due to dirty throttle, it wont happened like so obvious and so fast. it should be like snowball reaction, maybe bad fuel comsumption, respond sluggish, or rpm not stable. then only follow like engine stall if this continuously without remedy from the above symptoms. but my problem now is check light suddenly on and followed by engine stall. if no light, engine is running good. i'll talk to my forman tomorrow and see if he can find me a spare ecu to swap. may i knw how hard to swap an ecu? like makan kacang? :biggrin:
like makan ayam goreng :P
which type of Ayam Goreng? Berkasut Ayam or No Kasut Ayam? Lol~
---------- Post added at 12:38 AM ---------- 6 hour anti-bump limit - Previous post was at 12:31 AM ----------
Last time I do seal closed that PCV Valve, the engine become sluggish and appeared check engine light. Oops.. my engine is 4AGZE.
what bro levin818 said is correct. i took out the ecu and found out few legs of one IC looks like fried. went to mun lee and swapped ecu. no check light and running good. swapped old ecu back, check light on. after all bought a 5spd ecu cost me 600 without warranty given. usually kedai potong will give warranty or not?
ok, my car is using 6spd and AT ecu last time. i have bought 5spd ecu since they dont have stock for 6spd. after long drive from mun lee to subang and back to puchong, whenever my car was idle, sometimes rpm will dropped to 400+-. no check light and engine did not stalled this time. rpm went back to normal after i stepped a bit on the gas pedal. could this be ecu is still learning? or could this be because my previous ecu was AT and more fuel was flowing to the engine? do i need to adjust my fuel regulator after this to suit back MT ecu?
---------- Post added at 04:33 PM ---------- 6 hour anti-bump limit - Previous post was at 04:27 PM ----------
5sp ECU already cost RM600 ah? I thought that price is 6sp ECU. Kedai Potong no warranty, i think u better source is from levin818 for more guaranty.
600 no warranty...?
My rebuilt BT ECU has 1 yr warranty (unofficially can use until you sell your car w/o giving any problem), and it cost much lesser than 600 :biggrin:
---------- Post added at 01:47 AM ---------- 6 hour anti-bump limit - Previous post was at 01:46 AM ----------
Could it be your ECU in bad shape also :biggrin:
ai...sad sad sad. i need to use my car urgently because today need to go outstation. i knw you doing good job with warranty some more. sigh....if i take my ecu for you to replace the parts, how much for the charges? can pm me the price? next 2 weeks i dont have time to check forum here. will discuss with you about this when i come back.
bro; you won't regret if using a refurbished ecu by this sifu. with warranty and smooth output i really recommend this option. not to oversell his name, but i'm one of his customer. :proud:
hi all bros,
after long holiday, today i put back the batt cable and started my car. before changed ecu, rpm usually goes up to 1.5k during cold start. but it dint. rpm only up until 1k and dropped to 500-600. engine dint stall but very jerky. i keep pressing gas pedal to maintain rpm at 1.5k until engine fully warm up. after that rpm back to normal. drove car out for 30min and observed rpm status.everything was fine then. anyone got this problem? please please help me. :bawling:
Hon,
Try clean up your ISCV and 4-throttle.
Or let me check your 600 bucks ECU. It may be also in bad condition (worst situation).
Remember i have mentioned in previous post that, BT 5sp ECU is in the NG list now.
That's why chop shop will not give warranty on it.
Pls pm me your contact.
Hon,
if that ecu also got problem then really fuk ady. must pray hard now :adore:. pmed you.
Friend of mind replaced his ECU 3 times in one year... spent more than a thousand bucks!
You are not that bad at least.
u knw wat, after few days of driving, my car consider back to normal. finger cross the only thing different is last time using auto ecu, warm up time longer where it will took around 2mins++ for rpm to go down. where now it takes about 1min++. anyone here can tell me is this normal? now im still monitoring the conditions. if ecu kong next time, sure will find u already. kekek at least warranty secured.
