hello guys..
From ur experience,what type of racing clutch is the best for C160 gb n how about the price?![]()
it is not about what clutch is best suit with the gearbox.
its what u want to achieve with that gearbox and clutch system is matters.
Ogura or OS Giken but standard BT go for Super Single is more than enough. No need to go for twin plate...![]()
bro nothing, what is clutch system la?
Sifu is correct...Stock BT go for OS or Ogura Super Single is very rich guy la....
For me I will go for Exedy lightened flywheel & Exedy 3 puck with clutch cover set.. This is more than enough...![]()
I definitely disagree with "Ogura Racing Clutch set is expensive and for rich people only"
ORC Super Single comes with :
- clutch cover
- clutch
- flywheel
= New for Rm3200.00
Have you check?
- how long can exedy 3 puck use (Mileage)?
- how much is a new flywheel?
If you can sum it, i think you may agree with me. Pls bear in mind, i'm not saying exedy is not good, but disagree with the statement above "ORC is for rich people"
so, how's your ORC doing so far? nice? is it super-hard ah? do they come in pressure plate and clutch only? duwan flywheel (what's the weight of it anyway?).
was thinking of exedy 3 puck or trinity la... :hmmmm:
Softer than exedy 3 puck that i'm using previously, and i didn't dismantle the flywheel off from the clutch to weigh it. But on the rev side, i felt it is heavier than my previous HKS flywheel (4.6kg) slightly. Bite wise, it is the same as exedy, and that may be due to my car's puny horses generated . I'm measuring how long it will last with the kilometres travel.
ORC comes in a set with flywheel or the replacement clutch kit only. You can't use the clutch without the flywheel. Oh ya, it came with the clutch bearing, which i assume it is a racing bearing.
poor me...
