SOS....
I got a distress called from my neighbour that his colleague car has splashes of acid causing the white spot on the paint surface
WATCH out for these guys..(M'sia A/C usually fitted on top )
..picure for illustration used only
I should not have meet up with him at night & as many thing wouldnlt shown up under street lamp & bad finding. Deatiling appoinment set for !st Jan makr a begining of a new day for a new year
I got a shock to find out what actually happen under day light when i saw the car, the acid splatted actually corroded the car paint.. will elllaborate more
here are some of the pics of the Spotted leopard -
some paint defect pic discovered along the way (pics Before)
paint chiped
some stains
left side rear bumper ...evidence of chewing gum stick till the rear
rear bumper scratches
some scratches before corrections
More evidence of the spots
if you see carefully u actually these spots actually look like crater on the moon
closer pics
My Rescue mission is to lose the spot on this leopard
Aim to get it corrected & restored
Menu for this ride
TBW - with an 1oz of APC to get rid of whatever that is on the surface
APC dilution 1:10 on all wheels, I am not a brightener person, dont feel comfortable to stronger acid...i am pleased with all the
Clay with Mild - Meguairs Last Touch
Dealing with OEM soft Clear coat
initial test Meguiar's #80 - Speed Glaze polish with Cutting Foam Pad on Rotary & upgraded to a more aggresive DOuble sided wool pad still not achieving the results i want, Then I call to discus the severity with the owner & advising him the details & damaged - resorting to wet sanding -
if i continue to compound, i may damaged this soft clear coat & the intense heats actually melts everything else.... he says go ahead to do the rest & i Wetsanded the whole bonnet - 200 unigrit sand paper
Meguiar's #105- Ultimate polish with double sided wool pad
and follow with Meguiar's #105 Cutting Foam Pad
Meguiar's #80 - Speed Glaze polish with Cutting Foam Pad on roof areas
Meguiar's #80 - Speed Glaze polish with Polishing Foam Pad
finishing off with Meguair's NXT2.0- Synthetic Sealant 2.0
& seal with Meguiar's Ultimate quik detailer
The glass is polish with single side wool & a special formulated glass Polish
some engine pics before
stainted water marks on the plastic well
Bonnet pics before
engine after
close up after engine detail
wheel before
APC agotating at work
wheel brush
now a clean wheel
the detail of a clean wheel
wheel arch ...before
paint chiped
some stains
closer pics
Menu for this ride
Bonnet pics before
engine after
wheel before
wheel brush
now a clean wheel
