WTA: Rear disk for CS3A - help needed
chengbenny
Subang Jaya
Hi sifusss out there,
Do anyone convert their rear disk from drum to disk? Recently, I bought a halfcut (4G93T GDI - ralliart version) and its come with front rear disk with 5 holes 114.3 pcd but not rear.
Do you think which rear disc with 5 holes compatible and can fitted to CS3A? please help ....:hmmmm:
you can mod the mitsu fto rear brake to fit your cs3..5 hole 114.3 pcd
lancer7891 : Thanks for that ... FTO rear disk brake really can fit in CS3, I have fitted it nicely and with some little modification and change rear chamber kit to adjustable ...
---------- Post added at 10:37 PM ---------- Previous post was at 10:35 PM ----------
Direct fit if you can source Cedia Wagon rear disc (forumer from trinituner had did it)
trinituner.com :: View Forum - MITSUBISHI
Kampoon: Thanks for the source ... I have fitted it with FTO rear break ..
Good to hear that ....u using twin pot at front ??
how much u spend o modify the rear to disc....need to left car overnight ?
I might be intrested as well.........:P
Its cost about less than 1K, 400 for the fto disk, 180 for the adjustable toe and about 200 for the handbrake cable ... labour cost not sure... coz my car in the midst of transplant the engine ... I guess no need overnight, should be half a day work ...
Ooo yea, the rims need to changes as well, from 4 holes to 5 holes (FTO disk) ...
