bro... adding to above,
pls advice if stock car, wira 1.5 can use waja 1.6 stock spring for front? rear? or both?
reason for asking is, each time the wira going over bump, sure kena below (even slow slow also same) dun mention some aunties drive wira like those equestrian-horse-jumping-over-the-fence-of-bars style.. see also scare..
the 1.6/1.8 spring diameter is different (bigger) so need to change the absorbers as well...if not the springs can't sit in the absorber cup of 1.3/1.5 which is slightly smaller....
I'm new to this section.. hv been thinking to upgrade my wheel from 15 to 16.. currently driving gen-2.. what are the things i should consider before making any purchase? Thanks in advance..
does anyone have a set of extra ABS controller ? those are situated behind the car near the fuel tank... i need one... mine was not suitable due to previous owner changed to a 95' FD hydraulic pump but the...
