Avance VVTC
glanza
kl/kelate
Is it a good stuff? Im planning to install this into my car but i dont know much about it.. Anyone mind to share here? Such as how it works, its power gain.. Otai2 help me plz..
aiyoo.. no one about this ka? poor me..:bawling:
Bump: aiyoo..no one knows about this ka? poor me..:bawling:
ayoo...sory la..maybe nobody here dont use the vvt cont. la...
me oso dont want to use this la..why u wnat to control ur vvt?
how much this stuff cost u?
sory i didnt ans ur qs...maybe other member can give some opinion la...
I just want to know whether it can help my BT from sluggish at low rpm or not. Coz people said we can control vvt to engage at any rpm we want. So i think it can help a bit. It doesn't cost me a lot, if more than 500 sure i'll go for e-manage.
Its ok t-la, juz want to korek2 saja hehe
ya la...why? ur bt sluggish ka? better u change sport extractor and power intake lah...hahaha
pcmod
itu video apa u post eh?
how to determine vvt just by looking tachometer eh?
yeah, newer version of 20v, blacktop and last batch of silvertop, will use TPS for feeding and ecu will determine whether to on vvt or not. so from my vvt light, i can see ecu activating vvt as low as 1000rpm.
maybe using vvt controller in blacktop, you can kasik lambat vvt masuk. supaya jimat minyak.
and sudah ada blitz ecu pun u mau control2 lagi ka?
and just read ur thread regarding that ecu. macam mana la ecu can control pressure minyak? hahhahahha.... maybe i need to relearn back from basic la like this.
:hmmmm: vvt lambat masuk then lambat keluar?
better let the ecu do the job since u hv blitz ecu.
:proud: blitz ecu can increase oil pressure??? really???
pcmod
ceo, i think that car tap the VVT signal to the (ABS) indicator .. u see the indicator on and off....
oh, that abs led.
hahahha i thought ada cara baru.
at first, saw that abs led and think that 'how can once vvt masuk (led blink), then led switched off, then blink again, then switched off again, then blink again.' - cause vvt triggered continuously.
didnt see the tacho needle. not full throttle.
eh ya la, lambat masuk, lambat keluar. high rev application. good for track. better buy la this vvt controller.
beli2, jangan tak beli..
pcmod
Aiyo that's not me said that la, that sabahan maa.. I also confused bout that haha..
Since the stuff exist, maybe it has 'something to do' la i think.. Actualy i dont know wat is the diferent btween blitz ecu n stock one..no info la.
Bump:
pcmod
Bro n0th1n, actually that vid the meter needle not very clear coz background too bright. Anyways, I was trying to explain in that vid that VVT can activate at partial throttle (not full throttle) and around 2000RPM as well.
So in that vid, ABS light was used as VVT indicator (my car has no ABS). And the reason why it ON and OFF coz I was playing with the throttle to explain how VVT works. You can also notice the change in engine note in the video, which is consisted with the VVT activation/deactivation.
New Posts
