ok..sory guys..currently im using 4g63, as u know it can't endorse.. so, my plan is, i wanna my chge my 4g63 to 4g67.. juz change engine kosong.. izit possible to chge like dat or need to mod a lot..
i think i know what mospeda is trying to say...
wut he meant was,
use the 4g67 blok together with the internal just for the sake of endorsing it...rite?
i'm not sure the intake & exhaust manifold of 4g67 and 63 are the same...
u can refer to the the sifus in here...
this is the things that i'd learn from my previous car with 67's block..hope it will help a bit:
if ur original 63 engine comes from the VR4's family then only minor engineering have to be done
e.g; block reboring process..and if for extra precaution step just install the oil squitters considering 67's block is from the n.a's version
even the VR4's crankshaft and its conrod are the same with 4G67-except the pistons
oil-pump also PnP and u'll have urself a 2.0L setup cover-up by 1836 roadtax issuance..hehe
the problems come when ur base set-up is comin from the newer 63's (evo 1,2,3)
note that these blocks aren't the same like VR4-(if u intend to use back the evo's crankshaft n etc including the oil-pump have to be modified to fit in the 67's block!!)
few minor issues such as the head studs will also involved
that means extra $$$ have to be pull-out
happy modding..![]()
yes.. u were rite zarique.. juz for endorse.. then i chge back to 63.. if posible, i wil do like that, if not do like wat owndferra said..
i believe u refering to the aftermarket piston and rod compare to the storker kit which is comes
piston kits,rod and billet cranksaft...as far as im concern for example cosworth stoker,piston r made from 4032 alloy n wiseco piston kit r made from 2618 alloy...i didnt noe much on the relibility of this material n i gues sifu will xplain more..sifus...help.![]()
that is normal aftermarket material...but for Extreme for 850-1000hp above it's diference material.Many fastest car in the world did not mantion u guys.And the fastest car are not stock block.All big cc and crazy stroker.2.4L he stroke near to 2.9L
i'll give my idea n advise base on what i know so!
i will choose to reply or not...
